Question about Olympus Stylus Verve S / ?-181 mini S Digital Camera
Dial on the top
What does the dial on the top do?
    Master:
  • 852 Answers
This dial is the mode dial. It allows you to switch between shooting mode, recording mode (movies) and playback mode.
Posted on Sep 01, 2005
What Does the top left dail on the Michael Kors mk8184 mean? Or what does it do?
The 3 dials are for the Chronograph function! The top left dial indicates minutes! Top right dial indicates hours and bottom dial indicates seconds!
Oct 13, 2014 | Watches
Where can i find watch dial for shc041
Firstly, what is a shc041? The cleats are called dial feet. They orient the dial to the movement so 12 is always at the top. When they break the dial spins around. Three solutions. Anew dial from the manufacture. A used dial from another watch, maybe from a popular auction site, or "dial dots". Small adhesive dots used to adhere dials with broken dial feet to movements. Sometimes successful, sometimes not. A forthis to send the dial to a dial refinishing company and have new feet soldered on.
Oct 19, 2011 | Seiko SHC041 Watch
What do the 3 dials do on a bracer watch style 07301333
1.the dial on the right top is the 1/10 second timer 2.the dial on the left top is 30 minutes timer 3. the dial in the bottom is the one showing seconds, otherwise called as seconds hand.
Jun 29, 2010 | Bulova Watch
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
INSTRUCTIONS NEEDED ON HOW TO SET UP SPEED DIAL NUMBERS FOR WHOLE OFFICE SYSTEM
Speed dial numbers 001 -255 (01- 70 on older versions) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
Jan 08, 2010 | NorStar T7316E Corded Phone
AE-1 film dial not sitting properly
That can be a problem. The ASA dial has a post that links to another ring under the top cover. The ring under the cover is spring loaded via a tungsten cable that travels the span of the top of the camera to the rewind side. If you are not careful, the cable could break.
To get to the dial, unscrew the cap screw that holds the film advance lever on. The cap screw has 2 small holes for a specific tool, but small needle nose pliers with fine points will work. The lever can be removed with 2 washers along with it. You can now see the retaining nut for the dial. It is best to set the dial at 'B', 3200 ASA. Use the same pliers to remove the nut. The dial can be removed at this point. Best to lift it on the far side near the edge of the top. If the dial itself is damaged, I probably have a good used one. The ring under the top has a notch for the ASA dial post, at rest it should be at about 10:00 oclock. With the ASA dial still set at B/3200, lean the post into the notch and slowly turn it counter-clockwise till the ASA dial can be seated fully. Reassemble the other parts in the reverse order.
Dec 19, 2009 | Canon EOS-AE-1 35mm SLR Camera
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
Press the chg key
Oct 14, 2009 | NorStar M7310 Corded Phone
The dial on the top
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Olympus Stylus Verve S / ?-181 mini S Digital Camera Logo
47 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
