Question about Clarion DXZ375MP CD Player
INTERMITTENT POWER PROBLEMS
I have a 1994 Nissan Pathfinder,with a Clarion dxz375mp ,it appears to have an intermittent power problem,sometimes the radio stays on and drains the battery overnight WITHOUT the key in ignition,even if you turn off the radio the clock still appears and you can push the source button and turn it on without the keys in ignition and radio plays or CD will operate,I checked all the wiring diagrams from the radio to the car and everything appears to be connected properly
Wiring diagram power windows 94pathfinder
Posted on Apr 29, 2012
  • 61 Answers
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Posted on Mar 29, 2009
Sometimes my clarion stereo won't turn on and it needs a couple of tries to hit the power button on
you need to contact clarion and tell them the problem sounds like you have a defective stereo and they should replace it under warranty
Mar 24, 2014 | Clarion NX602 In-Dash Car GPS Navigation
I have a 2003 nissan pathfinder. The digital clock keeps fading on and off. Sometimes its lit completely and other times its faded or completely off. What would be the problem?
Intermittent activity is a sign that the clock is dying. This is a very common issue with Pathfinder clocks, unfortunately. They were manufactured pretty poorly. If you want to have it repaired with a lifetime guarantee, please check out www.autoclockrepair.com. All the info is there on how to remove the clock. Drop me a note if you have any questions, thanks!
Jan 25, 2011 | 2001 Nissan Pathfinder
Power windows and power locks dont work
First,check the fuses. If they are good, your power window/lock module(s) may be bad,or there may be an intermittent connection somewhere in the wiring.
Oct 19, 2010 | 1995 Nissan Pathfinder
Intermittent spark: 1994 Mercury Capri
I would suspect that you have a loose connection inside the distributor or in the ignition wiring. Give it a good visual inspection. Also, after dark, have someone start the car while you observe under the hood for any arcing or sparking. Doing this at night allows you to see where trouble may be located. Let me know what you find. saailer@att.net
Dec 05, 2009 | 1994 Mercury Capri
98 Nissan Pathfinder with gauge glitches
Its very common on a lot of cars, the instrument cluster has a number of connectors soldered onto the circuit board, the solder joints get loose or are bad to begin with and you will get these kinds of intermittent display issues. They are a pain to fix because the entire cluster has to be removed, just to solder the joints! The soldering is the easy part, re/re of the unit is the real pain. If you go through the trouble make sure you also inspect every solder joint on the board while its out..you don't want to do it a second time!
Jun 20, 2009 | 2000 Nissan Pathfinder
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
Need wiring diagam
ok , here is the owners manual if you need it , maybe programming instructions are in there .
http://www.clarion.com/us/en/MungoBlobs/547/503/DXZ375MP-ENG.pdf
ok here is the installation instructions straight from clarion .
http://www.clarion.com/us/en/MungoBlobs/777/794/DXZ375MP-INST.pdf
and if you might need your vehicle schematics you might look here .
http://www.the12volt.com/
Johnny
Jan 14, 2009 | Clarion DXZ375MP CD Player
Intermittent Starting problem
Check for good connections at the battery cables, Check the condition of the cables themselves and be sure that your fuse box is free from corrossion.
Jun 13, 2008 | 1994 Nissan Pathfinder
I do not have a manual to see how to setup the my Clarion DXZ375MP radio. Where can I get a manual?
go to the clarion site(www.clarion.com) and put in the dxz375mp number in the search section and it will take you to that cd player and you can download the instruction manual and the installation manual on the upper right hand corner.
Feb 29, 2008 | Clarion DXZ375MP CD Player
Clarion DXZ375MP CD Player Logo
273 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
