Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Conquest UltraEase Plus Water Filtration System ice dispenser
The unit is making ice just fine and dispenses water, however, when I select ice (crushed or cube) neither wants to come out. The auger just churns....making a noise and nothing comes out. I have to open the door and manually take the ice from the holding container. We received this refer with a home purchase, so there is a home warrenty to cover an expense. Our question is, is it worth our $55 to call for service or find the part to repair ourselves..................
  • chscheu May 23, 2009
    The motor cranks, but no ice comes out. I looked at the mechanism and the connecting gear from the motor had sheared off.
    I need to find a replacement gear, but am having a hard time locating the piece. Can anyone provide a website or shop that can identify the part?
    It's probably a $3 part that is easy to put in... no sense paying a repair guy $250 to come out and fix it
  • annandjean Aug 02, 2010
    How do I clean the ice dispenser on my Whirlpool Ultra Ease Plus? Thankyou
  • 639 Answers
ngfam1 here for you!
I am happy to be of assistance!
It is not worth doing it your self!!!!
Sometimes its not easy to find out what part is bad on a
side X side with ice and water on the door, even for the trained tech. call service!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
Posted on Aug 26, 2008
Whirlpool Side by Side, Ultraease Water Filter System: Problem, won't make ice, water flows fine from door but water for ice maker won't fill to make ice. Any suggestions?
Posted on May 29, 2010
I purchased a new whirlpool conquest and have had on for two days. i have water coming out of the water dispenser but still no ice production. There is no water in the chute leading to the ice maker. ...
Maybe it won't call for water until it goes through the cycle. Try putting water in the ice mold and see if it starts working when it freezes and dumps the ice. Make sure the water line is open by swapping the wires on the dual water inlet valve. Then the water dispenser will send water to the ice maker and you'll know the valve and line works.
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ultraease refrigerator (ED7FHG) making water sounds, and drips water onto steel pan in bottom rear of freezer side. Purchased new. This is an obvious change. Problem?
You have a water leak somewhere (I'm assuming this water sound is constant). If not write me back for other possible solutions.
The only place water comes into the freezer is for an ice maker or a door water dispenser. Check around the ice maker for a leak. If there is a water dispenser in the door then check the piping to it also.
There is a drain in the bottom of the freezer compartment which is there so when the frost is melted by the defrost heaters, it has somewhere to go. This drain drains into the "drip pan" (or condensate pan) in the bottom of the unit. Here the water will sit until it is evaporated into the air.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool 21.7 cu. ft. Top Freezer...
"pipe hammer" from water line to in door ice/water dispenser
try to turn down the valve that feeds your refrigerator water inlet to see if that can help. It's most likely that you have too much water pressure feeding the unit and the valve is having a hard time closing off the flow of water. Good luck and have a Happy New Year.
Jan 05, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Jan 03, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
External water dispenser on Whirlpool Conquest model GS6SHAXKS01
Try this first. In the inlet side( where the little water line comes in) there is a small screen where the water is hooked up. Shut off the water and unhook the water line. there should be a small screen to keep out particles from entering your ice make/ water dispenser. See if that screen is plugged. If so clean the screen. you can put it in vinager over night if you want. It will help clean it.
Jan 27, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
1,414 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
