Question about Lands Phones
Where to get a new phone battery in Orlando Fl area. Handset will not ake a charge on base.
  • 79 Answers
Radio Shack 2001 S Orange Ave
Orlando, FL 32806 Map (1.32 miles)
Posted on Aug 25, 2008
New cordless phone showing out of range
Check that it is registered with the base station and check the range coverage. If you are not out of area of coverage and handset is properly registered to base station then your handset may be faulty.
Dec 12, 2014 | Lands Phones
Batteries won't charge
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
I hope this helps.
Jun 18, 2014 | Uniden DECT 6.0 Cordless Telephone...
Where can I find a Samsung repair center? in Orlando, Fl
Best place for Samsung repair (including Samsung Galaxy S3 and Galaxy S2 Screen / Glass repairs) is XpressFix and 1 Hour Cell Phone Repair. They are the place for cheap Samsung repair and Galaxy Glass replacement in Orlando, FL. Samsung Galaxy Screen Repair Orlando or try this site for Samsung Galaxy Glass Repair in Orlando, FL They also offer iPhone repair services.
Sep 03, 2012 | Samsung Galaxy Tab 101 Tablet...
I have put new batteries in my diverse 4016 phone on the base but it will not charge.can you please sugest what the problem maybe' thanking vou ...
It looks that the handset is not charging from the base unit: if you have a multimeter you can check that you have a voltage slightly higher than your battery pack voltage on the base unit. Make sure the contacts are clean and If you have no reading, then the charger on the base unit is very likely defective.
If you do not have a multimeter, check and clean the (two) contacts on your handset and base unit to ensure proper electrical contact and that you see the charging indicator displayed on both the base and the handset.
If that does not work, to assess if the issue is with the handset, swap the phones from the base and the stand-alone charging station and repeat the test: if it works, swap the batteries between the handset to see if it makes any difference. If it works, then the issue might be with the original base unit handset as you have now 'tested' the new battery on the alternative handset. To summarize, it is a test by trial and error swapping.
Hope the information is of assistance.
Sep 26, 2010 | GE 27851FE2 Phone
Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
joequevedo@charter.net
May 07, 2009 | GE 27992GE5 Cordless Phone
My phone goes dead while dialing
It might sound obvious but have you checked that the batteries are charging properly?
Can you receive calls OK?
Jun 25, 2008 | Panasonic KX-TG1033S Cordless Phone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
My handset won't charge
Try charging it in a different cradle if you have more than one handset.  This has happened to me where a particular base will not charge a particular phone.  Once charged elsewhere the problem resolved.
Feb 14, 2008 | Motorola Mobility MD671 Cordless Phone
Base won't charge handset
the base of your handset needs to be repair take it to a tech
Apr 04, 2007 | GE 26938GE1 Cordless Phone
Lands Phones Logo
180 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
