Question about Casio Parts Cash Register PC Desktop
I have a problem with the Casio te-2200, the error IPL E02 displays on the and keyboard keys do not work, can anyone advise.
  • 737 Answers
Oh dear. The IPL is the operating system, or firmware of the machine. It may end up needing a new IPL loaded into it. I have never had an IPL error without a good reason. However, you can try the basic things first. Open the cover on the side of the machine, and you will see the socket(s) for connecting PC, scanner etc. Also in there is a small hole (it may have a piece of tape over it). Inside the hole is a little button. Put something gently in the hole (while turned on), and press the button. The screen should change to show 'init' or '000000000' or both.
Now, turn power off at wall.
Turn the key to PROGRAM or PGM mode
Hold down RECEIPT FEED.
Turn on power at wall.
When you see the display change to 'FFFFFFFFFFF' let go of RECEIPT FEED, then press SUBTOTAL.
If the display does not change to 'FFFFFFFFFFF' then DO NOT press SUBTOTAL, just leave the machine, and message me again.
If all went well, turn back to REG mode, and try it.
Mark
Posted on Aug 26, 2008
I have te-2400 frozen ... lcd works not showing any digits ... anyone can help
You have halted the firmware due to a failure to load IPL. This is recoverable if you do a hard reset. See your service and programming manuals for hard reset and IPL instructions. Make sure you have the correct IPL and loader for your region. If you don't need to replace the IPL then do not attempt it
Mar 23, 2017 | Retail Supplies
IPL fault, TE22000 how to troubleshoot?
Why were you trying to change the IPL? If you didn't have the new IPL and flashing software, you may have lost the firmware. Do you have the dealer IPL flashing software?
May 28, 2016 | Casio TE-2200 Cash Register
Hello i have te-2400 right now I'm getting IPL E10 Error , I called for repairing but they told me it won't repair again , I know it can repair but I'm looking for IPL and software but I couldn
Try your local community college data processing department. They can probably tell you where to get the software. You might also try some business based web groupds for an answer. Or you could look on eBay for a working replacement which may cheaper and quicker than the other option.
Nov 26, 2014 | Casio TE-2400 Electronic Cash Register
Casio te 2200
Hi Good Day!
Before you reprogrammed it, check everything first,
if there is a reset setting, try to use it before you reprogramming it.
Mar 26, 2014 | Casio Parts Cash Register PC Desktop
I want ONLY to clear buffer of TE-2200 without chaning anything else [i.e. logo, dept. key...] many thanks
unplug with key in program and press receipt feed while reconnecting power. should get all f's in display. then subtotal will clear the buffer only.
Aug 14, 2013 | Casio TE-2200 Cash Register
I can't add a name to a department key on a Casio TE-2200 cash registetr
Make sure you are using the text layout in the manual if the text is not inputting correctly. Also, don't forget to use the double zero button when changing between text input and placement to the keyboard.
If anyone needs a Casio TE-2200 or TE-2400 manual, C-tech collective have it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio5.php
Aug 01, 2012 | Casio Parts Cash Register PC Desktop
Hi casio cash register, TE-2200 wont let me sign in. Tried the method of pressing the receipt key and turning the key to progrram and pressing sub total. It gives me reciet and again it does not let me...
That is not how you sign in.
Turn the key to REG mode.Type your sign in number. If no PIN numbers have been changed, the sign in is 1.Press the CLK# button.
If anyone needs more information, the Casio TE-2200 and TE-2400 manual is here:
May 12, 2012 | Casio Parts Cash Register PC Desktop
I have a te-2200 but cannot get past the initialization. Machine initialization procedure. I keep getting a e004 error. Its in the d11D10D9D8D3D2D1 section that i keep getting stuck in.
Ok. I need to know these things:
1. which country is it being used in? 2. Do you want a PIN number to log staff on, or just simple log on? 3. Do you have a row of buttons next to the key called CLERK or CASHIER? 4. Will you be using a bar code scanner?
If anyone needs a Casio TE-2200, TE-2400 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jul 21, 2010 | Casio Parts Cash Register PC Desktop
I want get data in Flash Disk TE-2200 Casio
try to perform the instructions again. You've possibly missed something.
Aug 27, 2009 | Casio Parts Cash Register PC Desktop
Casio TE 2200 Needs mac codes
Hi.
What MAC code did you use? Are you getting an error on the display? Please describe what you have done so far and I'll try to help.
Mark
Feb 26, 2009 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
398 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
