Question about Canon PIXMA MP530 All-In-One InkJet Printer
Document in ADF error when faxing
Every time I fax something - it takes several tries. The error that comes up on the screen indicated "Document in ADF press ". Sometimes it takes over 10 tries before it grabs the paper. Is there something I can do to prevent this from happening?
  • califgrll Aug 26, 2008
    I'm having the same problem. I've had my MP530 for 20 months, use it lightly, and never had trouble using the ADF for faxes until the past month.
  • dave630 Nov 21, 2008
    I'm having the problem when using the ADF to copy documents. It just won't grap the documents. Neither Canon or the local sevice office have a clue.
  1. This problem is caused by refilling your ink cartridge but there is a solution
  2. When the ink is low or the computer thinks the ink is low the sheet feeder will not work
  3. You will notice that the in use/memory light is on
  4. The memory has a report it needs to print but does not want to print it without ink
  5. To print the report anyway do the following:
  6. Press the <FAX> button to enter the Fax menu.
  7. Press the <Menu> button. [FAX SETTINGS] is displayed
  8. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  9. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK. Select Yes. make sure there is paper in the printer.
  10. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
Posted on Aug 13, 2009
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
Check document error, no paper jam
It may be a bad hinge on the document feeder. I have seen several times where the left hinge ( when looking at machine from front) does not close all the way. Close the adf and look at the gap between the copier and the adf. The gap should be the same from the front to the back. If the gap is bigger at the rear ( when looking at the left side of the machine) then you need to replace the left hinge. You can also try pushing down on the document feeders' left side as it feeds the paper. if it works while pushing down, then it is the hinge.
Sep 05, 2012 | Canon Imagerunner 1025n
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
When trying to fax I get an error "open adf cover"...
You should be able to. It sounds like you've got a paper jam in the document feeder. Chances are there was a jam and part of the document (a small peice perhaps) is still lodged in the document feeder unit.
Aug 31, 2009 | Konica Minolta PagePro 1390MF All-In-One...
Reload/restart error
simply turned off and on several times.
wonders never cease, nor do errors (scan failure) with this MFC.
Feb 19, 2009 | HP OfficeJet D135 All-In-One InkJet...
ADF feed problem after going into the maintenance menu
Are you sure there's not something blocking the ADF.
Open it up and look inside, especially for a switch actuator being held down.
Oct 17, 2008 | Office Equipment & Supplies
Paper will not feed via ADF in Canon laser class 510 fax. keeps saying reset document when we try to fax or copy using either ADF or scanner. Briefly received error E337 (or could have been E377).
there is probably something in the paper path, double check and make sure no piece of paper is in it.
there is a small lever in the adf this is the sensor it should be able to move freeely and have a spring action, is it stuck?
are the guides set, and set to Letter?
Aug 26, 2008 | Office Equipment & Supplies
No copy and send fax from adf unit
First try reseting the unit by holding the * key and the enter button and the same time turn it on until it starts beeping. This will rest the machine. If this does not work. you need ADF rollers the can be purchased for 20 to 25 bucks
May 08, 2008 | HP LaserJet 3380 All-In-One Printer
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
CANON PC-1080F feeder error message
Well, open the adf and see if there's anything jammed in there. While you are at it, clean all the white out off the rollers and the scan glass. Then make sure the ADF cover is snapped shut properly
Feb 27, 2008 | Canon PC-1080F Plain Paper Laser Fax
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
191 people viewed this question
old marine
old marine
