Question about Palm TX Handheld
Palm v I am wondering why the lightning bolt icon stays on ...And it wont turn on unless it remains on the cradle holder..Please help
The lightning bolt indicates that the battery is being charged. I will stay on as long as it is being charged either in the cradle, or using an external charger. If it stays on after it is removed from any external power source, there is a problem with the unit and it needs serviced.
--Randy Miller
Posted on Oct 28, 2008
Hello, I can't turn off the flash on my nikon coolpix L20. Can anyone help me out?
In the shooting mode, press up-arrow on the multiselector (marked with a lightning bolt). Select the no-flash icon (lightning bolt in a circle with a slash through it), then press OK.
Oct 31, 2010 | Nikon COOLPIX L20 Digital Camera
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
IS THIS CAMERA WATERPROOF AND HO DO U TURN ON THE FLASLIGHT
No, the camera is not waterproof.
Touch the lightning bolt icon area until the flash icon appears on the left side of the display. This will activate the flash.
Touch the lightning bolt icon area again until the flash symbol appears on the LCD screen. This forces the flash function.
Touch the lightning bolt icon area again until the eyeball icon appears on the left. This activates the red-eye reduction mode.
To turn off the flash, touch the lightning bolt icon area again until the no-flash icon (lightning bolt inside a circle) appears on the left.
This is covered on pages 13-14 of the manual. If you've misplaced your manual, you can download one from the manufacturer's web site at http://vivitar.com
Jan 18, 2010 | Vivitar ViviCam 8025 Digital Camera
How do you use the flash on a vivicam 8025?
Jan 17, 2010 | Vivitar ViviCam 8025 Digital Camera
My flash does not seem to be working, I tried just about everything but it wont work. it all started when I pressed reset im pretty sure, but im not postive. please help me.
Pressing reset would not disable your flash. On the screen, does a lightning bolt icon appear? Is there a letter A or the word auto next to it? Or does the lightning bolt have a diagonal line through it? In any case, press the button on the back of your camera with the picture of the lightning bolt until the lightning bolt with "A" or "auto" appears next to it on the screen.
Dec 20, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
How do i fix a zire 21 palm it wont turn on, charge,work nothing
Hello.
From Palm support:
1. Press either the Date Book or Address Book button to see if
you can turn on your handheld that way.
2. Perform a soft reset: Use the tip of an unfolded paper clip
(or similar object without a sharp tip) to gently press the
reset button inside the hole on the back panel of your
handheld.
3. Make sure the power adapter is plugged securely into a
working electric outlet and is firmly connected to the
handheld. (If no outlet is available, your handheld can also
be charged through the USB cable, but this takes much
longer.)
Note: Your handheld does not have an indicator light to indicate that your handheld is being charged.
4. Charge for another three full hours.
5. If your handheld now turns on, check the charging-battery icon to ensure that your handheld is being charged. Example:
a. Connect the handheld to an outlet and turn it on.
b. Tap Home .
c. Look for the lightning bolt on the battery icon at the top of the screen.
d. If you do not see the lightning bolt, repeat steps 3 and 4.
Hope this helps.
Nov 03, 2009 | Palm Zire 21 P80730US Handheld
Fully charged put on cradle fatal alert/fatal exception/reset
the lightning bolt is normal ..its telling you the battery is being charged .. if you get an error code or if the unit quits working then you can do a reset or a "hard reset" ... the hard reset erases everything and will restore the unit to factory conditions .. to do a reset .. unscrew the top of the stylus .. that gives you a probe to push the reset button on the back (top) .. if you hold the power button in while you do a reset then it gives you a choice to "erase everything" .. if you accept then thats a hard reset ... if everything else fails .. do a hard reset .. you can do all this while its on the charger so if you have a bad battery that wont matter .. if the battery wont hold a charge then it can be replaced ..
Sep 03, 2009 | Palm m515 Handheld
Palm T/X Internet page download problems
Have you tried using Fast Mode to view your websites? With your browser open, select the lightning bolt icon on the top of the screen, then select Fast mode. You won't see pictures or icons, but the links will still be live. Good luck! Please let me know if this helps!
Nov 24, 2008 | Palm TX Handheld
Palm LifeDrive not charging
I had the exact same annoying problem. Easy fix though. Get the palm universal cradle. The power connector is either worn or loose and making partial contact. So when you use the normal adapter there might be a position that works but generally it won't. When you use the cradle the weight of the LD presses the contacts more and it will behave.
I went through a couple of chargers before getting the cradle and fixing it once and for all.
Apr 16, 2008 | Palm LifeDrive Mobile Manager Handheld
Just got Verizon 755p - can the power stay on while charging?
Try StOIC (Stay On In Cradle):
http://mytreo.net/downloads/stoic-stay-on-in-cradle,221.html
It's free and it works - the screen will stay on whenever the Treo is connected to charging power (e.g., in the cradle).
Enjoy!
- IntelelctArsenal
Jan 18, 2008 | Palm Treo 755p Smartphone
Palm TX Handheld Logo
211 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
