Question about Philips 46PP9302 46" Rear Projection Television
Philips 46 Rear Projection convergence off on part of the screen
I replaced the IC chips on a Philips 46. Convergence was good but I had the cloudy/fuzzy issue so I swapped out coolant in all the tubes. Everything went pretty smoothly. I pulled each one out individually, drained and refilled per the instructions. Once done I powered on the TV and started working the manual convergence. The red was way off and a bit crooked. I noticed that the coolant and lens assembly was a bit crooked when put back together. So I took the Red assembly back out and corrected this. Still slightly crooked on the convergence lines. The biggest problem is that Red alligns in the middle of the screen and has a nice picture. On the upper left side, it is way off. I had a DVD in and Paused. The PAUSED was split, with Red being a couple of inches off. The middle of the screen is aligned. Any ideas? Did I do something to the Red assembly during install? Can this be fixed easily?
  • Caveman08 Sep 02, 2008
    Thanks for the response. Are these alignment rings something I can turn while the power is applied to try to realign?
  • Philips Master
  • 8,617 Answers
You may have bumped the alignment rings on the convergence yoke on the red tube while doing the coolant as that could cause the symptom youre describing.
Posted on Sep 01, 2008
  • Sonny Berry
    Sonny Berry Sep 02, 2008
    yes , you have to be careful not to touch any circuit board, but if you adjust them from the front access panel behind the front speaker grille. just turn the little fingers that extend out, but do it gradually as a little movement goes along way. They should be marked with a line of white paint where the origional position was so you may just need to line the line back up on the rings.
46" projection tv ..colours were
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 16, 2010 | Philips 46PP9302 46" Rear Projection...
How can I tell if I have a projection bulb out? The screen is foggy and slightly yellowish. Is this fixable?
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Dec 14, 2010 | Philips 46PP9302 46" Rear Projection...
Having toruble getting the color adjusted and pic is very bright and fuzzy
  • Screen looks 3D
Dec 09, 2010 | Philips 55PW9363 55" Rear Projection...
Philips 46 in rear projection tv has too much green. The bulbs are good but adjusting the color does not help.
this models have coolent issues. I would tke off the front screen very carefully , as it may seperate , get a friend . Do not scrach the screen. then look down inside the units CRT's (Cathode Ray Tube) and see if its cloudy or fuzzy looking . While there look at the blue tube as well. If its fuzzy replace the coolent.
Jul 08, 2010 | Philips 43P8341 43" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Red color distortion hitachi 46f500
Can't remember which this one uses but its right on the chips. Check your resistors too.
Apr 08, 2009 | Hitachi 46F510 46" Projection HDTV
Couldy image
Problem #1 - Failure in the convergence circuits. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
Mar 14, 2009 | Philips 46PP9302 46" Rear Projection...
My panasonic big screen screen has shadows and fuzzy picture
  • Screen looks 3D
Dec 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
9p6040 c102 philips magnavox rear projection tv
  • Screen looks 3D
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
  • Screen looks 3D
Apr 08, 2008 | Philips 46PP9302 46" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
