Question about Sansui VRDVD4005 DVD Player/VCR
Looking for manual
Sansui vrdvd-2005 dual deck vcr/dvd recorder
  • 3 Answers
I have a Samsu Vcr-DVD player & it wont play DVD's in reading it comes up
Incorect Discc104 & I cant understand why also the DVD's are new can any one help please? suesbrushes@verizon.net thank u
Posted on Oct 26, 2008
  • Sue Roberts Oct 27, 2008
    Thank U I have it solved its Dirty I truly will keep what u say in mind for a more seriose problem Thanks much
    Thank U I have the salution all fixed now if I could find how to rate u I would but u were some what help full thanks
  • Sansui Master
  • 520 Answers
Call Sears parts at 800 469 4663.
Posted on Oct 23, 2008
How do i record from a vcr tape to a dvd on a sansui dual deck vcr dvd recorder?
If it is a combination VCR/DVD player,they usually can't do it.If you get a separate VCR player from a friend or neighbor,you can connect the VCR output to a cable box input,cable box output into DVD input,or if the DVD recorder has a digital tuner you can plug the VCR output player straight into the input of the DVD recorder.DVD recorders REQUIRE some form of digital input.That is why you need to route a VCR player through a cable box or the DVD recorder needs a digital tuner.If you are not sure if your recorder has a digital tuner,call sansui,they will know.I tried to find Sansui home and I found everything BUT DVD/VCR.If you have a manual it will be in there,or it may have a phone number on a label(back or bottom probably)of the unit.Good luck!Greg If you want to send me your model number,I will research it further too.It is up to you.
Aug 06, 2010 | Televison & Video
Manual for sansui vrdvd 4005 and remote
I believe it's available on a Sears sponsered website called managemylife.com. I hope this helps you. There's also info about getting parts (remote).
Dec 23, 2009 | Sansui VRDVD4005 DVD Player/VCR
User manual how to set clock on Sansui dual dvd vcr player.
Go into SYSTEM SETUP. thats where the clock settings are.
Mar 12, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
How can i find out about a user manual. i have lost mine. is it possible to get it off line and print it off.
go to site managemyhome.com you have to register for FREE FREE. I have been looking for about a year finilly found a site make sure up put in Sansui dvd/recorder vrdvd 4005 and you can down load pdf file. It is 88 pages but youdont have to print all if ypu dont want. I did anyway
Hope that this helps
Jan 08, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD-4000
this unit does not record dvds.
Feb 24, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
Jan 29, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui VRDVD 4005
I did have a look around but could only find manuals on eBay.
Dec 21, 2007 | Sansui VRDVD4005 DVD Player/VCR
Operating manual
order a manual from orion customer service 800 289 0980
Dec 11, 2007 | Sansui VRDVD4001 DVD Player/VCR
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
121 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
