Auto Zone is great for general parts but NOT for diagnosis problems. Did anybody check the CHARGING SYSTEM & CHECK FOR ELECTRICAL SHORTS? They will just change general parts. Have it ckd out properly & you'll see what I'm referring to.
The alarm and the central locking are all part of the remote keying system. You will not fix it with changing fuses because it is likely the ECU needs to be be reset. Unfortunately, it will require a visit to an authorised workshop to do this
Kindly check below matters on your freezer:
1. Compressor for defective. Please check the sound compressor, if still normal check the refrigerant . Please top up the gas if needed. If it is totally dead, you need to replace it with new one.
2. Thermostat for malfunction. This part will trigger the compressor to running and stop. You can test its operation while your compressor working normal. If your compressor is defective, the thermostat will not work.
So please fix the item #1 before you go the latter item.
Regards,
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
this may be a dumb question but have you turned up the signal. there should be a dial on the back that you can turn the power up. power light on, signal passing threw, the only other thing it can be is the built in amp itself may be dead.
