I have a sony kp57ws520. The set wont turn on and the lite blinks 9 times. I was told at one time to solder two specific diodes on the g-board and that worked for a period of time. Now the problem is back. Who can I send the board to for repair ? or is the set shot ?
  • 2,323 Answers
If you only solder them, this time around it looks like they might need to be replace.
Let me know if you need further assistance.
Posted on Aug 25, 2008
  • Jaime Hernandez Aug 25, 2008
    D6116 or D6301 is open (G Board). I would suggest to change them both just in case the has a short life span.
    I meant the other one has a short life span.
  • 4,234 Answers
Resoldering those parts is known as a temporary "fix". Those parts need to be replaced. I believe that they are D616 and D6301. Both are on the "G" board. I don't have a listing for your specific model, but most of thr 57s are similar.
Keep us posted.
Dan
Red lite blinks tv will not power up. Sony kdp-51ws655
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero detect circuit failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they repair it and return it). A new board costs about $80 on eBay without having to send them your (core) bad board. Sometimes they are not available and you must send your board in for repair. this is MUCH less expensive than SEARS, which charges several hundred dollars.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D6116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of the "G" board. Unplug the TV set, leave it for 10 hours (to discharge the capacitors). Remove the brown back, carefully unplug the cables, unscrew the two mount screws, and unclip the front retaining tab.
This is the MOST LIKELY failed component, D6301. It is a diode and MUST be unsoldered and replaced. Make sure you know that diodes have a SPECIFIC way they must be installed. Note where the stripe is on the component. You can locate a "good" diode by searching on eBay for "sony a1054157a". You should see a parts kit for about $25, give or take.
One other possible culprit is the D6116 diode. This is a surface mounted component (SMT) and will require a steady hand and a very fine-tipped solder iron. I would replace the D6301 FIRST and re-connect the "G" Board to see if that is the ONLY culprit. If you STILL have the same problem, then replace D6116.
Oct 02, 2010 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony Wega kp46wt520 no power up, 9 times it blinks red
You will need to replace the G board. You can try replacing the two diodes that usually fail, But because its a complex circuit with the zero cross detection the diode replacement never fixes the issue. Replacing or remanufacturing the G board is the only sure way to fix that issue.
Nov 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony 9 blink problem
9 blinks shows problem in power supply (G Board) and service manual suggest to check D6116 or D6301 that could be open on G Board.
Thanks.
Sep 01, 2009 | Sony KP-57WS520 57" Rear Projection...
TY,found scematics,ordered parts,mine only blinks 4 times though!Is this a different problem,am i wasting my time with the diodes?.Can hear aclick like a relay,when I try to turn on,standby blinks 4...
According to the self diagnostic system 4 thimes LED blinking,
The fault is in vertical section, Vertical deflection is stopped, 15V not supplied (D Board), IC 5101 could be faulty(D Board).
Therefore check the above mention area it will help you.
Thanks for using fixya.
Jun 28, 2009 | Sony KP-57WS520 57" Rear Projection...
9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Jan 05, 2009 | Sony KP-46WT520 46" Rear Projection...
KP-46WT520
IC8002 # 670581001 on D board .Ater replacing 3 diodes how many times does it blink now?
Jan 03, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
Nov 24, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Sony KP-51Ws520
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Apr 24, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony 32XBR400 Wont Power On
I do not believe the set is too far gone. The standby light blinks codes up to 7. If the standby light blinks more than 7 times it usually means that there is a short on the clock or data line. There are several small zener diodes connected to the clock and data lines in a couple of different places on the main board. Many times I have seen one of the zener diodes become very leaky, usually along the back of the board, loading down the clock or data line which produces the symptoms you are seeing. If you have no experience locating shorted zener diodes and unsoldering and soldering small parts, allow a qualified tech to service the set for you.
Aug 27, 2007 | Sony KV-36XBR400 36" TV
Televison & Video Logo
189 people viewed this question
Top Televison & Video Experts
Electro Med Services...
