Question about Nokia N73 Cellular Phone
Please help Sir please tell me the security code of N 73 The serial number is 357652016479476 my girlfriemd used my nokia n73 phone and changed the security code on it now i can not put a sim card or put the usb cable from the phone to the pc because as soon as i turn on the phone it ask me for the lock code.. can you please help my imei number is 357652016479476
  • 3 more comments
  • dom1411 Aug 25, 2008
    can you please help
  • dom1411 Aug 26, 2008
    im not looking for the service provider code im looking for the master code
    the code i need is for the phone its self as soon as i put my card in there it ask me for a lock code and that is the code i need
    still does not work
    sorry but its not that code the security code has changed and know all i can do is turn the phone on and the lock code comes up
  • 6,487 Answers
Try this one:
You need 1 mobile phones and a memory card reader.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card from the locked phone and put it into a memory card reader. Create
the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345".
Hope that helps..........
Posted on Aug 26, 2008
    Genius:
  • 2,035 Answers
Please click on this link:
http://unlock.nokiafree.org/
Good luck...
  • 435 Answers
Hi dom1411,
The lock code of the phone could be changed by:
Enter wrong lock code till your sim card becomes blocked.
Then it will ask for the PUK code which you will get from your service provider (Just call customer care of your service provider and ask for the PUK code, they will give your phone's PUK code)
It will then ask for new lock code.
Please try this given solution it will definitely work and please dont forget to rate this solution.......
Thanks.
  • Narmada Anand
    Narmada Anand Aug 26, 2008
    This is the simplest method by which you can unlock your phone without losing your valuable data in phone. If you format your phone , then all your phone data will be lost.......
    Master:
  • 763 Answers
Try to use restore factory settings and the code is 12345. it should be in almost all nokia handset.
im gonna find some solutions for that if nothing happens
CHARCOIS
  • 199 Answers
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot. The trick is by switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
but all your data will be lost
    Genius:
  • 1,447 Answers
Hi-
Chances are if you dont know the security code then you will not be able to access some settings, do you still have the PUK codes for the sim card? you can try several codes and when it locks it will ask for the PUK code of the sim card, you can use the PUK numbers then to reset it.
Hope this helps
Posted on Aug 25, 2008
  • 1,879 Answers
  • monk3ybidzness
    monk3ybidzness Aug 26, 2008
    If all the suggestions in here doesn't work and all the codes fromhttp://www.peters1.dk/ didn't help you either, the next step for you is:
    Go to a Nokia Service Center & bring a Proof of Purchase to end your issue.
    Master:
  • 521 Answers
Normally the security codes for nokia phones is ---1234---
or ---0000---.it should solve your problem.
pls do rate the solution
thanks.
regards.
fixya expert team
  • tech expert12 Aug 25, 2008
  • SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled. Phone Security Code:This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:Master Reset Code Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times. Which is the one that you want? Special Code/Service Provider Lock Code: This code is required to allow a phone locked to a particular network's SIM cards to be used with a SIM card from another network. Orange and T-mobile lock handsets in this way, though O2 and Vodafone are beginning to lock PAYG and WAP handsets. The unlock code varies from individual handset to handset. Blacklisting: This is not a security code, but it works like one! To help combat mobile phone thefts, the networks share a database of the IMEI (International Mobile Equipment Identity) of mobile phones that have been reported stolen. Once a phone is on this list, it will not be allowed to use any of the networks. This can be a risk if you buy a second-hand phone, because if it has been stolen, or if an unscrupulous seller makes an insurance claim after selling, the phone you bought in good faith may be permanently disabled. Be very careful to check the source of a second-hand phone! -----------------------------The default security code for Nokia is 12345 IMEI: 356406017443168 Master code: 5335036136Take your SIM card out first. This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (anything) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
  • please rate the solution and encourage the efforts of fixya experts team.thanks.keep me updated.
    Genius:
  • 3,422 Answers
You will have to get it unlocked from www.unlockexpert.com
  • Priya darshan Aug 25, 2008
    This is the only way to get the unlock code.
    IF you need anymore help let me know before rating the solution.
    Please don't forget to accept the solution as fixya.
  • 157 Answers
Hello sir
  • John Smith
    John Smith Aug 25, 2008
    here you go
    For free
    http://nfader.z-host.ru/
2 Suggested Answers
mohammed387
  • 1952 Answers
SOURCE: security code N 73
just u reinstall ur mob software and try....else u call to ur mob service customer care and tell ur last four digit no to them...then they ll give one code...use tat code and check it...
Posted on Aug 27, 2008
Security code N 73
What do you mean by Security code.
SIM pin code:
Master Reset Code
Blacklisting:
Jul 06, 2008 | Nokia N73 Cellular Phone
Security code for N73
12345.coz i use tat security code no 2 change my security code.i hope u change the security code no..its 4 ur hp safety.
Dec 24, 2008 | Nokia N73 Cellular Phone
Help me pleace phone code nokia 5800 Xpres musik
Go 2 ur SETTINGS->PHONE SETTINGS->SECURITY SETTINGS
->CHANGE ACCESS CODES->CHANGE SECURITY CODES.
if u hav not use ur security codes b4 this.key in 12345.after tat key in ur new security code no.
avoid ur sims card from bocking.change ur security level.use PHONE LEVEL.
i hope u can do it. ;)
License key for smartmovie
to download smart movie 3.41 in ur mobile in a simplest way please follow the link
http://gallery.mobile9.com/f/221998/
Sep 16, 2008 | Nokia N73 Cellular Phone
Forgotten N73 phone lock code
Report abuse
can you please help
Aug 23, 2008 | Nokia N73 Cellular Phone
Security code N 73
u need to concern the nokia care
Aug 13, 2008 | Nokia N73 Cellular Phone
Your security master code is 6513730566. Try this code.
Jun 27, 2008 | Nokia 6111 Cellular Phone
Security code
Your mobile IMEI no is :356406017443168
Just use this no to unlock your mobile :5335036136
This will definitely break your mobile security code ...........enjoy
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 26, 2008 | Nokia N73 Cellular Phone
Security Code for Nokia N73
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
Then I’ll give you the Master code to reset your Security code.
"I'm as confused as a baby in a topless bar."
Apr 12, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
103 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
