Question about Microsoft Xbox 360 Console
Xbox 360 disk drive
I've got a bad disk drive on my 360. I've been reading a lot about it, and I'm a little concerned about flashing my drive myself. I'm very mechanically inclined, but not very computer savvy. I was wondering if I bought the same Hitachi-LG drive that is the same rom ver- 0079fk, would I still need to flash it, or could I just plug and play? Even if I could, I've read that there are better drives out there, do you think I'd be doing this again in the future if I didn't upgrade?
Thanks!!
    Problem Solver:
  • 11 Answers
F you are unsure of how to flash a drive DO NOT DO It!! Sorry for yelling I just don't want you to brick your drive when you don't have to. Only a modder or hacker would ever have to flash their drives because they want to either play backup versions of games burned to media or exploit the software in someway. Your problem is much simpler and will not get you banned in any way. Just purchase the same exact model numbered drive, ROM version is not necessary but if available purchase it to be safe. Open up new drive and remove circuit board making sure your very gentle with the 4 or 5 small ribbon cables you will have to pull from their little connections. Most ribbon cables will simply need to be pulled straight out but depending on manufacturer or model number some ribbon cables will need you to flip up a simple little locking flap and then pull out. This is very important, as soon as you remove the brand new circuit board out of your new drive, grab a felt tip pen and write something directly on that board that will identify that board as not being your original. The unique key that matches original drive to original motherboard is on a chip on the board your now going to remove from your non working drive. Once the board is removed from the drive all that is left is hardware so by installing your old board into your new drive hardware you now have a brand new drive with your unique code still intact. Since you have to open your device to do this and that's what you planned on doing anyway I still want to let you know what you already know that this will void your warranty. Make sure you open up your device first before you order the replacement because believe it or not 9 out of 10 times all you will need to do is open up your so called bad drive and clean the lens very gently with a Q Tip dipped in Isopropyl alcohol. Now back to your desire to learn how to Flash a drive, well guess what, you now have something to practice with. Put the new board you can't use in the old drive hardware and flash away on that one using different scenarios you make up yourself depending on what you want to learn and if it ends up getting bricked you will still learn something without risking your precious gaming console
Posted on Aug 27, 2008
    New Friend:
Or, just adjust the laser. It will make the drive see game DVDs again.. not just some of them either. It takes about an hour or less and costs nothing. (
DVD = 3 ohms (yours will be 5 or 6 making laser weak)). Look up instructions on web like I did. Hope it helps.
Posted on Jan 05, 2015
    Sergeant:
    Novelist:
  • 166 Answers
If you install a drive in a 360 it has to be flashed. You would need to backup the firmware from the xbox drive thats installed and then flash it onto the new drive, This isnt to difficult to do, does require that you open the xbox and that voids your warranty.
You will find all the information you need here
http://forums.xbox-scene.com/index.php?showtopic=513412
Posted on Aug 25, 2008
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Xbox 360 dvd rom
Unfortantly to replace the dvd drive you would also need to flash the dvd rom with the corresponding code found in your hard drive.
Sep 21, 2009 | Microsoft Xbox 360 Console
My xbox 360 won't read my disks
if it does this with all the disks then your drive is either 1.drive is bad 2.firmware is corrupt. i would assume that your drive is bad, unless you have tried to hack your drive firmware and corrupted it. if you did try and hack the drive send me an email at nelsontimmy@hotmail.com and i can tell you how to reverse it.
Apr 17, 2009 | Microsoft Xbox 360 Console
X box gdr-8050l
If your xbox 360 has issues reading games, I would reccomend checking your warranty status and if possible sending it into microsoft for repair. You generally can repair it yourself by purchasing a replacement DVD drive, but it voids your warranty, and can also be a huge hassle(because you have to flash the drives firmware). Its generally worth paying a little bit extra to have microsoft do it for you.
Apr 12, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 disk drive stopped reading disks
Though i fixed the Disc Read Error myself within anhour but please test the below method at your OWN Risk. Please alsonote that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys.........
Apr 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont read any disk
Im not sure on the warranty. A year ago i had the 3 lights and microsoft replaced it free of charge. Call them up and ask them because most likely you may have a faulty lens/drive.
Mar 26, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont read disc
Though i fixed the Disc Read Error myself within an hour but please test the below method at your OWN Risk. Please also note that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourself within an hour. It also provides the money back guarantee in case you are not satisfied. As i fixed my Xbox myself so i thought to share it with you guys.
Jan 25, 2009 | Microsoft Xbox 360 Console
Xbox 360 disc drive
If you are unsure of how to flash a drive DO NOT DO It!! Sorry for yelling I just don't want you to brick your drive when you don't have to. Only a modder or hacker would ever have to flash their drives because they want to either play backup versions of games burned to media or exploit the software in someway. Your problem is much simpler and will not get you banned in any way. Just purchase the same exact model numbered drive, ROM version is not necessary but if available purchase it to be safe. Open up new drive and remove circuit board making sure your very gentle with the 4 or 5 small ribbon cables you will have to pull from their little connections. Most ribbon cables will simply need to be pulled straight out but depending on manufacturer or model number some ribbon cables will need you to flip up a simple little locking flap and then pull out. This is very important, as soon as you remove the brand new circuit board out of your new drive, grab a felt tip pen and write something directly on that board that will identify that board as not being your original. The unique key that matches original drive to original motherboard is on a chip on the board your now going to remove from your non working drive. Once the board is removed from the drive all that is left is hardware so by installing your old board into your new drive hardware you now have a brand new drive with your unique code still intact. Since you have to open your device to do this and that's what you planned on doing anyway I still want to let you know what you already know that this will void your warranty. Make sure you open up your device first before you order the replacement because believe it or not 9 out of 10 times all you will need to do is open up your so called bad drive and clean the lens very gently with a Q Tip dipped in Isopropyl alcohol. Now back to your desire to learn how to Flash a drive, well guess what, you now have something to practice with. Put the new board you can't use in the old drive hardware and flash away on that one using different scenarios you make up yourself depending on what you want to learn and if it ends up getting bricked you will still learn something without risking your precious gaming console
Aug 25, 2008 | Microsoft Xbox 360 Console
New Xbox 360 disk drive doesn't play games
well my friend thats because each xbox 360 drive is unique for each console so it only works on the original console, to solve this you have to flash the firmware from the old drive and put it the new one, there are many sites explaining it just google it.
Sep 17, 2007 | Microsoft Xbox 360 Console
New Xbox 360 Drive.. Need help flashing
You will need to backup the firmware from you original drive and flash it to your new drive as the old drive is tied to the motherboard with a 16 byte key
Microsoft Xbox 360 Console Logo
696 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
