Question about GE DBSR453EBWW Electric Dryer
Having problems with lights surging - GE DBSR453EBWW Electric Dryer
  • Kenneth Crowther
    Kenneth Crowther Oct 31, 2008
    actually I am a licensed electrician but I have just about exhausted my ideas. This house is my friends and he has added so many modern appliances, flat screens, computers etc. Just keeps getting surges.
    Scholar:
  • 121 Answers
Hi! kcmetal9901
Sound like you need to have an electrician check the main breaker panel and the circuit feeding the dryier etc. etc. etc.
Posted on Oct 30, 2008
Today my power went out for a split second and came back on I turn my TV back on it makes a high pitched whining noise and the screen wont turn on. Cant add picture but model number is MW30G71.
unplug your tv. let it sit for a good bit. 1/2 hour did your power just go out or did you have a power surge then no power. surges cause the grid to go down for a second too and that causes problems too. surge protectors are good for everything. also are you on cable? if so have the cable company check they're filters into the house may be an issue but check the tv after a half hour unplgged and then plug in and turn on normally? sometimes it needs a reset time period before the fuses inside will reset themselves.
Nov 17, 2015 | Televison & Video
Fix surging and missing problems
Do you have a check engine light?
Feb 06, 2015 | Cars & Trucks
Audi 2002 a4 v6 2.4l when the car first starts the RPMs surge up and down unsteadily this stops if you give a few revs on the accelerator pedal. When driving around 50kph the rpms surge slightly it feels...
You have two problems. The surging is from a dirty throttle body and /or air filter. The selector light could be from a bad selector switch or internal transmission problems. Have the car scanned for codes.
Oct 20, 2014 | 2002 Audi A4
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
One burner barely lights; others don't light at all.
This is a common problem with grills purchased after 2001 or with a full propane tank with a lot of pressure in it. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Feb 23, 2010 | Weber Genesis Silver B Grill
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
S80 engine surge at idle
You could have a bad or contaminated Mass Air Flow (MAF) sensor. You can get a used one online for less then 100. You can also purchase a can of MAF sensor cleaner at a local auto supplies store and clean it. It located right at the air filter housing.
Aug 03, 2009 | 2000 Volvo S80
Engine Surges and Lo trac light comes on then goes
1.Intake air vacuum leak. Check all hoses and bolts for tightness. With the engine running, wiggle all hoses around and listen for a hiss. 2. Change fuel filter, check fuel pressure. 3. Faulty idle control system/sensor.
Jun 19, 2009 | 2004 Chevrolet Cavalier
Ihave a sony KP53S75 TV there was apower surge and now there is no picture. The red light blinks 4 times can anyone tell me about this?
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Mar 25, 2009 | Sony KP-53S75 53" Rear Projection...
GE DBSR453EBWW Electric Dryer Logo
44 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
