Mitsubishi WD-C657 ,green led flashes fast then shuts off. When you turn tv on I get sound & no picture????
  • 2,071 Answers
Just cliick below for how they repair there DLP TV and a picture guide how to replaced the lamp,fan and color wheel .It seems your lamps is defected...
http://www.jangro.com/a/2006/08/15/samsung-dlp-frequent-questions/
how to change your Samsung DLP Lamp.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Hope this may help;
Regards,
VOTIT
Posted on Aug 25, 2008
  • 157 Answers
Hello sir
  • John Smith
    John Smith Aug 25, 2008
    lamp is dead. Youll need to replace the lamp
    Cheers
    Jigsaw
    XoXO
  • John Smith
    The user guide should give you instructions on how to replace the lamp
    Cheers
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
TV (wd-82738) shuts down unexpectedly and fast flashing green light comes on This occurs about once a week.
The tv flashing green light is on it have a word"LAMP"writing on the tv frame?Yes,than the tv projection lamp life it is ending.Tv unexpectedly shutdown the tv also have clicking noises sound too?That the board call the Ballast board is dying too,this board only job are only to ignite the projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp and might have also have to replaced the Ballast board too.
Apr 13, 2011 | Mitsubishi WD-82738 DLP TV
How to change tv lamp mitsubishi wd-c657
Read page 61 and 62, this s is the official Mitsubishi Owners Manual for you TV
http://static.highspeedbackbone.net/pdf/Mitsubishi-WD-C657-Manual.pdf
Jan 27, 2011 | Mitsubishi WD-C657 65" HDTV
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
Looking for a ballast part number and price Mitsubishi WD-C657
encompass.com or parstore.com is a good store parts.
Just provide model number tv.
Thank you
Aug 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV Shuts down
convergence amp IC's i would start with.
Dec 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
367 people viewed this question
Top Televison & Video Experts
