Question about Logitech Harmony 670 LCD Remote Control
Replace battery message came up. Batteries replaced but the replace battery message will not go away and remote will not work
  • Anonymous Sep 26, 2008
    I have essentially the same problem except my remote is working fine in spite of the "replace batteries" message. It's just kind of annoying.
4 Suggested Answers
SOURCE: system error
My harmony remote had the "system error 1"  I called Logitech and they said that it is a hardware failure and the remote is faulty.  After about 3 days they issued an RMA and sent me a new remote with no questions asked.  I didn't even have to send the old one back!  It took them a little while to get the ball rolling, but it did work.
Posted on Feb 22, 2008
SOURCE: weird battery size
Here's a link on the Directv forums. They suggest putting a small ball of aluminum foil between the positive terminal on the battery and the contact on the remote.
http://forums.directv.com/pe/action/forums/displaysinglethread?rootPostID=10316895
Posted on Jun 07, 2008
SOURCE: logictech harmony 550 universal remote trouble shooting
take out the batteries.when you are finished hold the #2 button while you put your batteries in and when you are finished it will say upgrade complete and then press any button.
Posted on Jan 27, 2009
Envirastation model dws 170
Usually it is due to bad batteries or remote is too far away from home unit. Put units next to each other and press the channel button on front of the home unit. It will start a search to find the remote. If it finds it with a temp reading press the channel button again and you should hear a beep. Channel is locked in. If you still do not get a temp reading try changing batteries in both units and try again. Another try is to unplug the home unit and wait several minutes with no batteries in either house unit or remote. Replace batteries in remote then in house unit and plug back into power. Set all settings and see if you get the reading. If not try step one again. Weak batteries will do the same thing as well as remote to far away from unit.
Oct 06, 2013 | Measuring Tools & Sensors
Tip
Dyson Cool fans and Hot + Cool heaters - Replacing the remote battery (Screw...
How to replace the battery in your Dyson Cool fan or Hot + Coolâ„¢ heater. This applies to remotes which include a base held in place with a screw.
If your remote control's signal range deteriorates, you made need to replace your remote's battery. Remove the screw from the base to release the battery. Please use battery type CR 2032.
Do not install backwards or short circuit the batteries. Do not attempt to dismantle or charge the batteries. Keep away from fire. Follow battery manufacturers' instructions when installing new batteries.
on Nov 27, 2014 | Dyson Dryers
Tip
Dyson Cool fans and Hot + Cool heaters - Replacing the remote battery (Non-screw...
How to replace the battery in your Dyson Cool fan or Hot + Coolâ„¢ heater's remote. This applies to remotes which include a push-fit base.
If your remote control's signal range deteriorates, you made need to replace your remote's battery. Press the end of the remote to release the battery. Please use battery type CR 2032.
The batteries keep going flat in my HP remote keyboard. The original batteries lasted about 12 months .When a notice appeared on the screen saying the battery was low i replaced them now they only last 2...
you might want to try quality batteries. When you replace the batteries let the keyboard set with no batteries for e.g. 5 minutes so that it "registers" that the batteries have been replaced. Maby disable the onscreen message and just use the keyboard untill it stops working :-)
Regards.
Apr 02, 2011 | Compaq Keyboard
Replaced batteries on my Harmony remote and I'm still getting replace batteries message on the lcd
Hi, try updating the firmware.
1. Connect the remote, and click "Downloads" in the software.
2. Click "Firmware"
4. Update the remote.
If that doesnt help then it's probably a hardware issue.
Dec 15, 2009 | Logitech Harmony 670 Advanced Universal...
ViewSonic RC00136P Not Working
Open the battery compartment, remove the batteries, and examine
the small springs at the POSITIVE end of each battery holder.
Sometimes these springs get compressed and no longer make
contact with the battery. Use a small knife point or small screw
driver to stretch the spring away from the case until it extends
about 1/8". Replace the batteries in their proper orientation and
try the remote. This worked for mine.
Jul 13, 2009 | Televison & Video
Weird battery size
use the AA batteries thats what i use and it still comes in and out
May 04, 2008 | Directv RC32RFK Remote Control
Tryng to get it to work on your satellite or tivo
New batteries or reproram again with new batteries installed.. This will solve your problem as it happens to mine whenever the batteries are low..Next time it starts playing up replace batteries staight away
Jan 03, 2008 | One For All URC-3021 Remote Control
Safe mode
To get your 550 out of safe mode, follow these steps.
1. Remove the batteries.
2. Hold the '2' button down.
3. While still holding the '2' button down, replace the batteries.
4. The remote will boot into the normal functionality.
Note: If the 'Off' button is held down while inserting the batteries, the remote will boot into 'Safe Mode'.
Sep 29, 2007 | Logitech Harmony 550 Remote Control
Logitech Harmony 670 LCD Remote Control Logo
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
