Question about RCA TruFlat 27F520T 27" TV
No channels It says that my tv is in analog mode and it only shows 3 channels. I have cable how do i get it to show me all of the channels?
    Genius:
  • RCA Master
  • 1,550 Answers
You need enter on the menu and change the tv entrance to cable because maybe is on aerial reception.Good luck
Posted on Aug 25, 2008
Add channels
Because thats all your TV can see is the feed out the cable box displays which in the US is channel 3. All cable companies encrypt their channels now so you have to have a cable box on every tv
Oct 19, 2014 | Televison & Video
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
I cannot get the Vcr/ Dvd to play
The TV needs to be on channel 3 not channel 3.1 because is a digital channel and the signal from the VCR is analog. Tune the TV to channel 3 to get the analog video from the VCR.
May 10, 2010 | Toshiba SD-V295
Stuck on a video mode
Some TV's disable inputs if there is no signal. I suggest confirming cables are connected properly, and accessing the system menu, and perform an autoscan for channels
Apr 27, 2009 | Initial HDTV-320 32 in. LCD TV
Digital channel signal blue screen only
Press the "INPUT" button and make sure "TV" is highlighted.
Mar 21, 2009 | Vizio VX20L 20 in. LCD TV
Screen shows no signal
HDTV sets are different from the old analog sets.
If your set is showing No Signal or Weak Signal you will have to do the following.
1) Connect an Antenna or Cable to the input on the back.
2) Go into the Channel signal source menu and select either the Air/Antenna or Cable option.
3) Go into the Auto Program Scan menu and SCAN in the channels.
Now you can watch available channels.
Dec 29, 2008 | Polaroid FLM-3732 Television
How to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Dec 19, 2008 | Televison & Video
JVC Television 56" in Digital Mode
somewhere in the tv's menu there will be something called autotune or channel settings. while in that part of the menu you should find something to change settings. also there are many inputs on the back of big screen tv's, you might try a different input like cable/antenna for instance. it may take a two way splitter to split the signal for both digital cable and analog cable. by next february the analog part of the cable may not work anyway.
May 02, 2008 | JVC AV-56P575 56" Rear Projection...
Tv want show
Oct 19, 2007 | Akai LCT3285TA 32 in. LCD Television
Tuner Problems
OK the tuner may be causing these problems, however first I would like you to go to your menu and set the RF pickup to antenna (This will allow analog channels) then come out of the memu and select a channel in the analog range channel 4, 7, or 9 try to tune in these channels. If this fails then you may have tuner problems the only way to be sure is to use a RF signal generator to send RF through the tuner and see if the video and audio being carried on that signal comes through. Sometimes the Internet connect gets messed up when the TV does not have the proper RF filters this may be your case. Try this use a Cable tv set top box and just set your TV to channel 3 for cable. This should Isolate the TV from the Internet cable modem and provide the signal needed by the TV.
Aug 19, 2007 | RCA 32V550T 32" TV
RCA TruFlat  27F520T 27" TV Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
