Question about Olympus Stylus Verve S / ?-181 mini S Digital Camera
Maintain all-weather capability
What do I need to do maintain all-weather capability of my camera?
    Master:
  • 852 Answers
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt-water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
Posted on Sep 01, 2005
What type of deck chair is more durable and easiest to maintain?
Plastic deck chairs are the most durable because they are not affected by the rain and bad weather. In addition, they are really easy to maintain and clean.
Aug 19, 2012 | Garden
Which Nikon S.L.R. cameras can I use my 70/300mm AF-S Nikor and still maintain auto focus, it is currently on a D40x
Every one (assuming the camera supports autofocus in the first place, of course--old film Nikons didn't). The lens has an autofocus motor, so the camera doesn't need one.
Film Nikons supported autofocus starting with the N2000. (Actually, the F3 also had autofocus capabilities, but used a different system). All the digitals support autofocus.
May 15, 2011 | Nikon Cameras
What is used to maintain weather stripping and door hinges
for weather stripping on your vehicle, if it is being stored use baby powder and work it in. If its being used regulary there are some great products out there 303, Vinylex, 3M Rubber Dressing, Wurths, etc.
As for the door hinges. A white lithium grease should work great.
Thank you,
Lee
Oct 01, 2010 | 2006 Ford F-150
Batteries won't maintain electrical connection
hi jensen,
in that case u'll have to change the body of the camera.
i can tell u a trick: place a piece of an aluminum foil (kitchen foil) between the contacts and the batteries. this will ensure a good connection.
try it and please rate this solution.
good luck!
Feb 13, 2009 | Vivitar ViviCam 3715 Digital Camera
All-weather
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
All-weather capability
The following steps can be taken to maintain the all-weather: Make sure that all the covers are closed before using the camera. The camera loses its all-weather capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Saltwater spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. If the rubber packing becomes worn or damaged, contact the nearest Olympus service center to obtain a replacement part.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Maintain all-weather capability of my camera
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. •Wipe any water off the camera before changing the battery or card. •If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. •Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. •If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. (A charge is made for replacement of parts.) •If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover, otherwise water may get inside the camera. •The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
Flash
Yes, the FL-CB05 Shoe Mount TTL flash cable will allow full TTL capability with the FL-40 flash off camera.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Stylus Verve S / ?-181 mini S Digital Camera Logo
74 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
