Usb connection is damaged inside the printer not the cable
  • 167 Answers
Place a service call, you will have enough trouble just getting the correct part.
Posted on Aug 25, 2008
Printer doesn't respond via USB only WiFi
As my helper partner states, I quite agree but I would also use a different USB which the one you're using might be damaged, use another USB station cause maybe its also damaged. But if it states that the printer is offline...it will never print because its not selected as your active Printer. Actually you are sending the printing jobs to that printer wich is not active or recognized.
Apr 06, 2014 | Office Equipment & Supplies
Hp laserjet p1006 has stopped printing. When I connect usb-cable til pc, I get the msg: usb device not rekogniced
This may help. Before you disconnected the USB cable did you "disconnect" it using the icon in the system tray? If you did not, try cycling power to the computer with no USB cable for the printer connected. Sometimes when you unplug a USB cable while it is still "connected" to the device your computer will lose track of that USB port. I hope this helps you.
Nov 13, 2017 | HP LASERJET P1006 Printer
Usb connection brack recionnection
Most external webcams directly hook up to a computer via a USB cable connection. However, if this cable is damaged, it will prevent the video signal from reaching the computer, rendering the web camera useless. Depending on the severity of the damage, you may be unable to correct the USB cable, but there are a few methods of checking and fixing the webcam's USB cable.
Disconnect the USB cable from your computer and check the connection port on the cable. If the cable is dirty or dusty, you will need to clean it to improve the connection and signal transfer. Spray a few shots of compressed air into the interior of the metal connection port. This will remove dust and other debris that may be stuck inside. Connect the USB port into a different connection port. Some USB connections do not accept all USB equipment, so changing the connection of the USB cable may correct any connection issues you are having. Look over the cable itself. If there are any tears or slight cuts in the wire, wrap electrical tape around it. This will seal off the damaged area while preventing any of the video signal from escaping through the open "wound." Delete the driver, then reinstall the driver for the webcam. The current driver may be damaged, so reinstalling it will correct the problem. Click "Start," "Control Panel," "System," "Hardware" and "Device Manager." Scroll through the list of drivers installed until you find the webcam listing. Right-click it and choose "Delete." Restart the computer, then insert the driver installation CD (provided with the webcam) and follow the onscreen prompts to install the driver back onto the computer.
Hope this helps.
Jan 14, 2013 | Computers & Internet
My dell 924 printer has stopped working. I get an error message that there is no USB connection. All connections & USB cable are fine. For some reason this printer is no longer on a USB port - have...
Hello.
It sounds like a issue with the hardware inside the printer. if possible try the printer on another PC, or try another USB Cable. Sometimes the cable can appear fine but can have small breaks inside it. You can also try your current cable on another persons printer to rule out the cable.
If you can not get the printer working on another persons computer I would suggest replacing it. it is cheaper than getting a tech to fix it.
Regards GM
May 27, 2011 | Dell 924 All-in-One InkJet Printer
INSTALATION
Try to connect the printer by using another USB Cable and in different port may the USB port in computer side or the usb cable is damaged that is why fail to send signal to your acer then try againt to install by using add hardware wizard
Jan 17, 2011 | HP DeskJet F380 All-In-One Printer
Brother printer will not recognise usb cable I can load printer onto laptop through usb cable now want to load onto dell pentium 4 and keeps coming up does not recognise usb cable so keeps asking you to...
Try a new cable and a different USB port. It's possible dirt is making for a bad connection or that the cable is slightly damaged and this other computer is more sensitive to the problem.
I hope this helps.
(who has dealt with a damaged USB cable that didn't look bad and gave an intermittent problem with one computer and associated hardware.)
Apr 10, 2010 | Brother DCP 115C All-In-One InkJet Printer
When connected to computer, displys
please install the drivers first and then try connecting
Mar 07, 2010 | HP LaserJet 1020 Printer
Canon Pixma ip3600 message saying printer is not online
This could be a problem with the port. If you have the printer attached to a USB hub, directly connect to the computer. Try connecting to a different USB port and test the current port with a known working device. Consider trying a new USB cable (minor damage could be a factor in signal loss).
I hope this helps.
Feb 04, 2010 | Canon PIXMA iP3600 Photo Printer
Printer not connected to hp laptop
If this laptop and printer combination worked before, try a new cable. They often fail inside without any notable outer damage.
Sep 18, 2009 | Dell A920 InkJet Printer
Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
jasbo
jasbo
