Printerscartridge What number cartridge do I use for a c4280printer
  • 24 Answers
Not sure which stylus fits my sl-2500 cartridge
The proper stylus is the best you can afford. However the cartridge itself will only take certain types. To find which simply enter the cartridge make and model number into Google and see what comes up.
Actually most hi-fi buffs say it's the cartridge and stylus combined that gives the best sound, since many cartridges fit only one stylus it's often the cartridge that is the real choice. Most turntables will take a wide range of cartridges, so you pay your money and take your pick.
Mar 31, 2014 | Gli Pro SL-2500 Turntable
Have an HP Deskjet 3050 and just replaced a black ink cartridge 61 with a black ink cartridge 56. Got an error message that says: "Cartridge problem. At least one of the Cartridges has a problem." Have...
On the inside of the cartridge door is the number of the cartridge you must use in your printer. If you put in another number, the electronic chip on the cartridge will tell the printer what type it is and the printer does not want to work with the cartridge. In the chip the printer also keeps track about the uses of the ink.
If number 56 is allowed too, perhaps another cartridge is empty too.
I think you did remove the pink label from the cartridge before you inserted it. because that label will block the electronic connection between the cartridge and the printer.
The manual explains how you can see what cartridge is causing trouble. When the printer is connected to a computer you also can use the computer to find out.
Oct 29, 2013 | HP Office Equipment & Supplies
How to reset ink level canon iP 2772??
Download and run the ipTool to reset your ink level :
http://www.mediafire.com/?nmj5nnzzjaw
Features IP Tool software:
  • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
  • Print test feature to test nozzle on the cartridge.
  • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
  • Changing the delay value for drying.
  • Set the printer model manually.
  • Reading and reset EEPROM printer.
  • Reset counter and reset ink level on the color and black cartridges.
Ink Level - shows the level ink:
  • BK - black cartridge.
  • CY - Cyan cartridge.
  • MG - Magenta cartridge.
  • YL - Yellow cartridge.
  • WM - Waste ink counter status.
  • WP - "additional" waste ink counter status.
Port Name - displays the port where the printer installed.
Port S / N - shows the serial number of the printer port.
Power - shows the number of:
  • ON - inclusions printer.
  • OFF - to turn off the printer.
Cartridge Info - Displays information status of:
  • CL - colored cartridge.
Head Parking - displays the number of parking.
Head Cleaning - shows the number how many time the cartridge cleaned.
Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
Cartridge Replacement - shows the number of cartridge replacements:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 20, 2010 | Office Equipment & Supplies
What numbers for cartridges for lexmark 2500
hello
go to the link below , it will give you the user guide : in it you will be able to get the part numbers for the various cartridges.
http://www.lexmark.com/publications/pdfs/2007/2500/v3709407_en.pdf
Item Part number Average cartridge standard page yield is up to1
Black cartridge p/n 28A
High yield black cartridge p/n 34
Color cartridge p/n 29A
High yield color cartridge p/n 35
Photo cartridge p/n 31
please rate my service
Nov 30, 2010 | Office Equipment & Supplies
How to install ink cartridg
  1. Make sure the All-In-One is on.
  2. Pull the control panel toward you, and then open the cartridge access door.
  3. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy.
  1. Pull the old cartridges toward you, and then lift them out. Store them in an air tight container or dispose of them.
  2. If you are installing new cartridges, remove the sticker and transparent tape from the bottom of the cartridges.
Warning: Do not touch the gold contact area on the cartridges.
  1. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
  2. Push back firmly on the cartridges until they snap securely into place.
  3. Close the cartridge access door, and then close the control panel.
  4. Load paper into the paper support and adjust the paper guide.
  5. Use the buttons on the control panel to answer the questions that appear on the display:
  1. If the color cartridge you installed is new (it has never been used), press Select.
If it is old (it has been used), press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the color cartridge you are using, press Select.
If it is not the number of the color cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. If the black cartridge you installed is new, press Select.
If it is old, press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the black cartridge you are using, press Select.
If it is not the number of the black cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. Continue with Aligning the print cartridges to ensure proper installation.
Note: You can also use the Lexmark Solution Center to install the print cartridges. For help, see Using the Lexmark Solution Center.
Oct 28, 2010 | Lexmark X4270 All-In-One InkJet Printer
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
I need to know how to get to the ink cartridges on
  1. Use the buttons on the control panel to answer the questions that appear on the display:
  2. If the color cartridge you installed is new (it has never been used), press Select.
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Lexmark Solution Center.
  • From the All-In-One Center, click the Maintain/Troubleshoot tab, and then click on a topic.
    Here is the manual
    Hope that helps you :)
Nov 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
Hp 670 printer cartridge numbers
as i m not exactly confirmed because the printer is very old.but the cartridge number for black is  51629 and for colour is 51649.but before buying this new cartridges just check out on the box of the cartridges that does your printer number is listed on the box. thanks.
Jan 11, 2009 | HP DeskJet 670c InkJet Printer
DO I HAVE TO HAVE THE SAME NUMBER INK CARTRIDGES EVERYTIME I BUY THEM OR DOES THE NUMBER NOT MATTER?
In general, you have to buy the same number of the cartridge, otherwise your printer will give error message. in some cases, there are compatible cartridge that will work with your printer but you have to check  the cartridge box which indicate the model number of the printer. I hope this solve your issue
Oct 20, 2008 | Office Equipment & Supplies
276 people viewed this question
k24674
