Car radio not saving stations but have used car loom from skoda to roadstar head unit ,so iso plugs go straight in and eveything works but take out keys stations are lost and cd,s not remembering where they last were stopped. help ||||||
    Genius:
  • 1,550 Answers
My dear friend all the stereos got a two cables to feed the stereo the red put on the ignition wire and the yellow on a direct source to the battery positive lead maybe you don´t put the yellow one correctly.Good luck
Posted on Aug 25, 2008
Can be fixed an Original Skoda Fabia 2003 radio that gets stuck changing stations?
Anything can be fixed. I would check the front panel switches first.
Jul 12, 2017 | Skoda Cars & Trucks
I've bought a S/H car fitted with the excellent Alpine CDM 7871 R head unit. When I start the motor up and switch the radio on I have to search for stations each time as it doesn't store the last set it...
this is one for a radio tech but generally if it will not store set stations then it is finger trouble and that means the way you are selecting and saving stations Most systems you find the station you want and then hold down that preselect button until the station moves on. For a correct answer find a shop that sells and installs your brand of wireless and have then explain the procedure of setting and saving selections.
Jul 09, 2014 | 2000 Hyundai Accent
JVC KD-R312 CD player keeps resetting itself whenever the ignition is turned off. The radio stations are ok, but mybass, treble, loudness etc always resets itself. Is annoying because i ahve to go through...
You are losing the permenant 12VDC on the Radio. This is the thick yellow wire from the radio loom, it has to be connected all the time to 12VDC.
Cheers
Oct 27, 2010 | JVC Car Audio & Video
How to change radior on 1999 landrover dicovery
I'm assuming Radio - in which case just get some release clips (varies from radio to radio) and insert them and then using the clips pull the radio towards you. IIRC the D2 uses standard ISO looms so you should be able to plug straight in.
If your vehicle had premium Audio, the loom may be different as the premium system goes through a amp under the passenger (RHD) seat. On LHD vehicles it may be under the drivers seat. If you have a CD Changer under one seat, it'll be under the other! These may require either an adaptor loom or the plug being modified.
Feb 28, 2010 | 1999 Land Rover Discovery
No radio will work in my car: Light just come on that it not even on the screen.
if you've used the loome plugged into the car check that the wires line up and the car has enough wires most new head units have 6 wires while most older cars only have 5 therefore you need to bypass the stereos ignition wire by joining it to the live wire and reconnecting all other wires as they would on the loome
May 12, 2009 | Car Audio & Video
I am scraping my M reg ford fiesta, radio is good
there should be a short section of wiring loom from the rear of the head unit to two connector blocks.These a usually universal from car to car, just take that from the fiesta and plug straight into peugot. Failing that you can buy them at most auto factors.
May 01, 2009 | Car Audio & Video
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
No radio sound from my IVA-D310E
neither of those units use fibre optic cables! but it sounds like you puled out the antenna wire behind the head unit. if you try and search radio stations without the manual tune on and it keeps changing frequency on it and never stops then its the antenna plug.
Nov 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Replacing audio equipment
Asked at a car parts shop and they had the rightadapter being for the car make. Many thanks for responding and being able to help if needed. From Sue.
Jun 15, 2008 | Car Audio & Video
Radio stations
The +12V_Memory (pin 4 on A connector) must be connected to a permanent (not shutoff by ignition key) +12V.
HTH
Jan 22, 2008 | Roadstar CD-258US/512 CD Player
210 people viewed this question
 Grubhead
Grubhead
