Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Blowing Lamps I have the Sony Grand KDF-42WE655 (2005 model). The TV failed and by the indicator light, I replaced the lamp ($130.00) after running just a few hours, the TV started to shut off. I could turn it back on but in no time the indicator light was back on. I heard a noise from the lamp area as I tried to turn it on. I removed the replacement lamp and found it shattered like the first lamp. Please give some suggestions as to what the problem may be. At least, if I cannot repair it myself, I will have an idication of the problem when I send it off to be serviced. I am also trying to determine the value of the TV so I can assess how much I am willing to pay for repair. thanks!!
  • Anonymous Aug 26, 2008
    I installed the sony lamp one this is recommended in the TV manual
  • 10,594 Answers
Let me know, have you installed Original Sony lamp or refurbished from some where?
Sony Genuine Lamp is available on Sony Direct Accessories @ $200.00
Posted on Aug 25, 2008
Kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Feb 07, 2012 | Sony KDF-E50A11E TV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Lamp replacement procedure is easy and written in user manual.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
It overheats and pops the Xl-2100u lamp?
by pops? do you mean it explode? how many lamps? it could be the fan that supposed to be ventilating the lamp or it could be the the ballast, why the ballast because the ballast regulates the voltage in order the keep the lamp on, for ignition it sends around 15,000 volts after that it regulates the votage to a small amount of voltage around 5,000 so it could be sending the big amount of voltage all the time never regulates that or it could be regulating and then sending another big amount of voltage over and over until the lamp doesnt handle those changes.
Apr 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The on lcd little light blink six time
The standby light blinks to indicate problems with the TV. Six blinks indicates an internal problem, I suspect with the lamp. I recommend contacting a Sony repair shop to vacuum out the TV and replace the lamp. Installing it yourself has no bulb warranty and you cannot vacuum it out without taking it apart. Lamps are $250+ each...
Mar 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The tv man replaced the lamp and now 4 days later .. i'm getting 3 blinking red lights tv will not turn on .. thanks
Ballast board Call Encompas Parts 1-800-638-3328
You can order Lamps at Mats for $99.00 and up
1-800-628-1118
FOX Lamps $109.00-$139.00 1-800-227-5369
Jan 18, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Picture goes blank AND SOUND goes off together, both back on too
it can still be the lamp for some reason these sony tv's will exibit these symptoms when the lamps are getting weak. by the way when the lamp goes out the entire tv shuts off no video or audio, just to let you know.
Aug 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Wega 55 inch, won't turn on and displays shows lamp problem? How do I resolve this? Thanks
Please replace lamp in TV and lamp replacement procedure is written in user manual of TV.
Please buy Sony original lamp for your TV and avoid aftermarket / cheap lamps.
Need further info, let me know with model number of Sony TV.
Apr 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY WEGA KDF-50WE655
Did you replace your lamp with a generic lamp? Many generic lamps do not produce as much light as OEM lamps do. Also, you may have a separate issue causing the picture to appear less clear than before. Check my solutions to other Sony LCD owners who have had problems with their optical blocks( light engines)
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
