After I replaced the lower blower wheel and there is no water in the tank, I'm still getting a red flashing light and a stop flashing message. What to do?After I replaced the lower blower wheel and there is no water in the tank, I'm still getting a red flashing light and a stop flashing message.
What to do?
You can't post conmments that contain an email address.
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
3 red lights happens because the GPU and the CPU overheat and shut down to prevent damage, you will need to send it in to get it fixed, or you can fix it yourself using a good video guide
Your system will need the 3 red light service. The 2 red lights flashing indicates overheating. We can fix this for you if interested email for estimate [email protected]
Thanks
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 3 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 3 red lights. Even before you get the 3 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 3 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that’s all.
if all three except the upper right are flashing then i am afraid u have the RROD-red ring of death..call microsoft and they will send u a replacement after u describe the problem..i had three such replacements!!! hope u get urs running ASAP!
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
3 Red Lights Flashing - is a general hardware failure
Unplug everything and let it sit for 20 min. Re-connect and try re-starting
If
these steps do not resolve the behavior, turn the console off, remove
the hard drive, and then turn on the console. If the 3x Red LED error
light is no longer displayed, turn the console off, re-attach the hard
Check the lights on the
power supply. When you turn on the console, the power supply light
should illuminate green even if the three lights on the console flash
red.
