Question about Russell Hobbs 9209 Classic 4-Slice Toaster
Russell Hobbs 9209 Classic toaster
I have cleaned electromagnetic plates, (if that's what they are?) But still no joy. Several elements heat up but lever will not stay down. Can you help please?
Bryan
  • 3 Answers
I had the same problem which I managed to solve. The electro magnet that holds the toast lever down takes its power from a poor joint.
Remove the bottom of the toaster. You will see 2 wires encased in a heat proof sleeving going from the small circuit board. One of these wires dissapears up inside the heating element board about mid way along the board. You will now have to remove the metal covering by twisting 6 tabs. This is best done by taking off the black knobs you use to push the toast down - if you can - I couldnt, so I had to use long nosed pliers to bend the tabs and then with difficulty, remove the metal cover. YOu should now see the terminal that the wire is connected to. It is this connection that fails either between the wire and coonnector or connector and heatin element on the reverse side. I put a small bolt through the hole and used a nut to tighten the pressed fitting. I didnt use solder because I thought that it would just melt!
Anyway, my toaster worked after that. Russell Hobbs failed to give me any advice at all.
I hope that has helped.
Neville
Welwyn Herts
Posted on Mar 28, 2009
  • Steve Blackburn
    Steve Blackburn Dec 11, 2014
    Couldn't get the bottom moulding and wiring to separate and the elements all seem to be built into one block that is part of the steel cover. BUT when I put the thing back together all elements worked! (for now, at least). Thanks, Neville
Toaster won't turn off
its broken, retun it to the place you brought it and demand a refund
Nov 22, 2013 | Russell Hobbs 18117 4-Slice Deluxe Toaster...
New elements for Russell Hobbs Toaster 9276
go to an appliance repair shop and see it parts are available. go on the web--google-- russel hobbs toaster ---parts department and give your model number.
May 26, 2013 | Russell Hobbs 9276 Toaster
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
Manual for Russell Hobbs breadmaker 4461
Ask the breadmaker manual search engine:
manualfox.com/searchengine/breadmaker.htm
If they find it, they will provide you a direct download link.
Jul 25, 2010 | Russell Hobbs 9209 Classic 4-Slice Toaster
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
bought a new toaster I would like any account you have created for me to be deleted. thank you
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Apr 01, 2009 | Russell Hobbs Toaster Ovens
Russell Hobbs 9376 Classic 2-Slice Toaster
Possibly a GFI on an outlet of the same circuit as the toaster needs to be reset?
We had the same problem and so came here. When I read "replaced the fuse in the plug" my husband asked about the outlet GFI switches (he replaced the outlets last year, so he remembered they had GFI switches). One GFI on the toaster's circuit had "blown" and so needed to be reset. Before relegating the toaster to the recycling bin, check the it by plugging it into an outlet you know is working.
Dec 27, 2008 | Russell Hobbs 9376 Classic 2-Slice Toaster
Russell Hobbs 9209 Classic 4-Slice Toaster Logo
803 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
