Have a Philips 32PF9830/10 menu keeps popping up on screen . Have renoved batteries from remote , reset remote to factory settings have turned tv and sky plus off and unplugged and put back on. Menu reappears either 1 minute after you put tv on or 30 mins. I suspect software problem? Can you help
Hey, i have just had the same problem... did you manage to get this fixed?? and how??
Posted on Aug 06, 2010
How do I get the promo display off my screen on a Samsung PDP TV series 4+ 600hz
For this model, you will need to reset the TV and go through the first time set up again. To do this, use the remote when the TV is turned off and push mute, 1, 8, 2, power in that order. The service menu will come up. Select options, then factory reset. The set will then power off. Turn the set back on and go through the first time set up, making sure you pick home and not store. Hope this helps.
Apr 09, 2016 | Samsung Televison & Video
Need information on a philips t.v. model 32PT6441/37
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 12, 2008 | Televison & Video
How can I reset my Philips 37 in flat screen TV back to the factory settings?
You haven't mentioned the model no. of your TV. Nonetheless, the reset procedure for the model nos. 42PFL7409/98 / 42PFL7409S/98 goes like this:
1- Press Home,
2- Select [Setup] > [Installation] > [Factory
settings],
3- Press play to enter the [Factory settings]
menu
[Reset] is highlighted,
4- Press OK to reset to default settings.
5- Press Home to exit.
The reset procedure may differ for other model nos.
Furthermore, Press the "Menu" button to access the menu, and select "TV Settings" and then "Picture" to bring up the picture settings. Adjust the color, brightness, sharpness and other settings if the picture seems off. Select "Dynamic Contrast" to have the contrast adjust to screen changes and "Digital Noise Reduction" to cut down on outside interference and reduce noise in the signal. On the "Installation" menu, select "Reset AV Settings" to have the settings reset to their factory defaults.
I hope the above helps.
Good luck.
Jan 11, 2011 | Philips Televison & Video
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Menu Screen keeps popping up, interrupting cable stream on tv
You have it in the demo mode go into menu and turn it off.
Aug 06, 2009 | Televison & Video
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Total Factory default of Philips 37pfl9703
hold down menu button on set until it does a factory reset
Dec 07, 2008 | Philips 32PF9966 32 in. HD-Ready LCD...
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Televison & Video Logo
276 people viewed this question
Top Televison & Video Experts
