Question about Olympus Stylus Verve / ?-mini Digital Camera
The dial on the top
What does the dial on the top do?
    Master:
  • 852 Answers
This dial is the mode dial. It allows you to switch between shooting mode, recording mode (movies) and playback mode.
Posted on Sep 01, 2005
SOURCE:
What Does the top left dail on the Michael Kors mk8184 mean? Or what does it do?
The 3 dials are for the Chronograph function! The top left dial indicates minutes! Top right dial indicates hours and bottom dial indicates seconds!
Oct 13, 2014 | Watches
What do the 3 dials do on a bracer watch style 07301333
1.the dial on the right top is the 1/10 second timer 2.the dial on the left top is 30 minutes timer 3. the dial in the bottom is the one showing seconds, otherwise called as seconds hand.
Jun 29, 2010 | Bulova Watch
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
The manual does not say what the dials are for on the top right side of the unit under filter. What is the purpose of this 2 digit dial?
Kenmore 85244 Air Purifier Air Purifier The manual does not say what the... Answer Failed: retry The manual does not say what the dials are for on the top right side of the unit under filter. What... (More) (More) The manual does not say what the dials are for on the top right side of the unit under filter. What is the purpose of this 2 digit dial?
Feb 18, 2010 | Kenmore 85244 Air Purifier
AE-1 film dial not sitting properly
That can be a problem. The ASA dial has a post that links to another ring under the top cover. The ring under the cover is spring loaded via a tungsten cable that travels the span of the top of the camera to the rewind side. If you are not careful, the cable could break.
To get to the dial, unscrew the cap screw that holds the film advance lever on. The cap screw has 2 small holes for a specific tool, but small needle nose pliers with fine points will work. The lever can be removed with 2 washers along with it. You can now see the retaining nut for the dial. It is best to set the dial at 'B', 3200 ASA. Use the same pliers to remove the nut. The dial can be removed at this point. Best to lift it on the far side near the edge of the top. If the dial itself is damaged, I probably have a good used one. The ring under the top has a notch for the ASA dial post, at rest it should be at about 10:00 oclock. With the ASA dial still set at B/3200, lean the post into the notch and slowly turn it counter-clockwise till the ASA dial can be seated fully. Reassemble the other parts in the reverse order.
Dec 19, 2009 | Canon EOS-AE-1 35mm SLR Camera
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
Oct 14, 2009 | NorStar M7310 Corded Phone
Cannot set dials on a Paul Jardin watch which came w/out instruct
THE OTHER 3 DIALS ARE FAKE AND DON'T DO ANYTHING,IF YOU LOOK CLOSELY THEY ARE JUST MORE OR LESS TACKED IN PLACE.
Feb 22, 2009 | Bulova Millennia Motion 96B34 Wristwatch
Dial on the top
Sep 01, 2005 | Olympus Stylus Verve S / ?-181 mini S...
Olympus Stylus Verve / ?-mini Digital Camera Logo
57 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
