Some problems it could be is a fuse,fuel pump relay,wiring problem at the fuel pump when you replaced the pump.recheck your work you may find the problem there.
I checked the voltage at the plug for the fuel pump and im only getting 5 to 7 volts it seems to jump around in that range
the fuel pump needs 12 volts to operate.check the voltage in and out of the relay for the fuel pump circuit if this is okay then you are loosing voltage between the relay and the pump plug.,which will have to be checked out.also make sure the ground circuit is good as this will affect the reading assuming you used the plug ground circuit to check pump voltage.
