Question about Hotpoint HSS25GFP Side by Side Refrigerator
No water at dispenser
Ref. makes ice just fine but no water at dispenser in door.
  • workload3 Nov 01, 2008
    Any person knows that a service call is a final option. The reason for this forum is to resolve the problem by saving money. Answering with a solicitation isn't to beneficial to the forum.
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Perhaps you should try service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
I own a Whirlpool side-by-side mode # GD5PHAXKQ00. The ice maker quit working so called a repair person. He said we needed new circuit boards. We ordered on-line and replaced them. We are still not...
ok when u check solenoid there were two of them one is icemaker one is water. ok. now after water leaves solenoid it runs up the back of ref. make sure u dont have a bubble in that line if it does there is a vaccum and wont allow water to make it up to icemaker., if it has undo water line as it goes into back of ref. and make sure water is coming up to there. try that ok..
Feb 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
In-door water dispenser doesn't work.
The water supply to the door is frozen up inside the door and about the quickest way is to use a hair dryer with the ref in the off position and freezer door open warm the area with the hair dryer. This will take a while, be patient but the only other alternative is to turn ref off for 24 hours with the freezer door left in the open position. Remember have patience if using the hair dryer method. Good luck and hope this helps.
Feb 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirpool ref. stop making ice. There is water
feed valve most likelly cause remove wtr. line if water comes out water valve is somthing to look at if it has power
Jan 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
Jan 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
62 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
