Question about GE DPGT750GC Gas Dryer
Problem with "model selection connection" message on touch screen
My touch screen reads: "A problem has been detected with the model selection connection" and I cannot get any response from any of the buttons to access the troubleshooter menu.
Is there any help for me?
GE Dryer - Profile Harmony
DPTGT750GC1WW and perhaps others.
If a screen comes up with "model selection connection". It could be the motherboard that has problems. Most likely not the touch screen.
Possible solution - Before calling for repair.
- First unplug the dryer for two minutes.
- Hand spin the dryer drum one or two turns while unplugged. ( in case motor was over heated)
- Make sure the dryer door is fully closed.
- Plug in (after the two minutes).
- Cross fingers
- Start.
- Let dryer cool between loads when possible.
If this fails you may need to call for repairs. I think GE has one year repair plan unless you bought extended plan. If you paid with credit card, see if it was a paid with a credit card that extends warranty another year. Perhaps look into this "card choice" for your next high end purchase.
Only if this helped...Donations_M.D.,box774,Fairfax,CA - Another try if this fails - If you dare - Unplug, you can remove about three screws holding top panel on (on rear) and tilt top forward. Check to see that all connectors are seating well on motherboard. (White box in center). Hope see works for you!
WE04X10105 Display
WE04X10107 Power/PCB ASM-Main (motherboard)
WE04X10127 Power filter (circ) EMC
Posted on Nov 13, 2008
2002 chevy malibu cranks wont start. fuel and temp gauge dont work. radio reads cal
Cranks won't start , Did you check for spark ,fuel pressure ?
Radio Setup .Will the vehicle communicate with a scan tool ? Fuel an temp gauges not working are probably bad step motors inside the instrument cluster that controls the gauges . Where do the gauges read 0 or something else ?
Engine Coolant Temperature Gage
The IPC displays the engine coolant temperature as determined by the PCM. The body control module (BCM) receives a class 2 message from the PCM indicating the engine coolant temperature. The BCM converts the engine coolant temperature into a percent gage deflection. The IPC receives a message from the BCM via the serial peripheral interface (SPI) indicating the requested gage position. The engine coolant temperature gage defaults to 38°C (100°F) or below if:
The PCM detects a malfunction in the engine coolant temperature sensor circuit.
The BCM detects a loss of class 2 communications with the PCM.
The IPC detects a loss of SPI communications with the BCM.
Fuel Gage
The IPC displays the fuel level as determined by the PCM. The body control module (BCM) receives a class 2 message from the PCM indicating the fuel level percent. The BCM converts the fuel level percent into a percent gage deflection. The IPC receives a message from the BCM via the serial peripheral interface (SPI) indicating the requested gage position. The fuel gage defaults to E (empty) if:
The PCM detects a malfunction in the fuel level sensor circuit.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates.
DTC P0462
The fuel level sensor changes resistance based on fuel level. The PCM monitors the signal circuit of the fuel level sensor in order to determine fuel level. When the fuel tank is full, the sensor resistance is high and the PCM senses a high signal voltage. When the fuel tank is empty, the sensor resistance is low and the PCM senses a low signal voltage. The PCM uses the signal circuit of the fuel level sensor in order to calculate the total remaining fuel in the tank. The PCM sends the fuel level percent via the class 2 serial data circuit to the body control module (BCM). The BCM converts this data and sends a fuel gage percent deflection to the IPC via the serial peripheral interface (SPI) in order to control the fuel gage. The fuel level information is also used for misfire and EVAP diagnostics.
For the DE 100 series radio, complete the following procedure, using a scan tool, in order to properly set up communication:
  1. At the Main Menu screen, select: Diagnostics.
  2. At the Vehicle Identification screen, select the following options:
  3. ?€¢
    Model Year
    Passenger Car
  4. At the System Selection Menu screen, select: Body.
  5. At the Vehicle Identification screen, select the Platform type.
  6. At the Body screen, select: Radio.
  7. At the Radio screen, select: Special Functions.
  8. At the Special Functions screen, select: Radio Setup.
  9. At the Radio Setup screen, press ENTER. The following test will set up a new or existing radio.
  10. Select one of the following options:
  11. ?€¢
  12. Press the ENTER key.
  13. Verify that the scan tool displays "Test in Progress."
  14. Verify that the scan tool displays "Test Completed Successfully."
  15. Press EXIT on the scan tool.
Important: The radio set up will configure the following systems:
Diagnostic Trouble Codes
Class 2 Radio Messages
Country Code
Chime Volume
Chime Level
12/24 Hour Clock
Without learning the VIN, the radio will display a locked message (LOC).
The radio setup procedure will also clear the following messages:
May 29, 2016 | Cars & Trucks
How do enable my touchscreen?
This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer)
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Nov 24, 2015 | Lenovo Computers & Internet
How do I open text messages?
Go you your messaging application and press ok or touch it depending if you have a phone with a keyboard or touchscreen. Then go to whoever sent you the message on the messaging screen and select it until you can read the text message.
Sep 02, 2015 | Motorola Cell Phones
How do i tell if my touch screen is detected?
You were most likely lied to by the repair place. Many models offer both non-touch and touchscreen models. The touchscreens fail more often and are harder to procure so many shady resellers pass off the non-touch models instead.
Aug 26, 2014 | Lenovo IdeaPad Yoga 2 Pro
How can i update my iPod model # MC086LL
The iPod touch is not only a music player, but also your gateway to the world via the Internet. In order to connect to the iTunes music store and use the email and web-browsing features of your iPod touch, you must first connect to a wireless network.
Touch the "Settings" icon on the home screen of the iPod touch. The iPod does not require you to press down very hard to select an icon. Using your finger, lightly tap the application you want to activate it. Choose the Wi-Fi setting and turn it on. You may need to wait a moment while the device locates available networks. Select the wireless network you want to connect to. You may have more than one option based on your location. If you are prompted for a password, enter it and touch "Join." Opt to have your iPod alert you when there is a new network you can join. This can be useful if you are no longer in range of a network you have previously used. To receive these messages, turn on the "Ask to Join Networks" feature. Tell the iPod touch to "forget" a wireless network that you no longer want to use, so it will not automatically try to connect you. Under the Wi-Fi settings, tap the ">" button next to the network you want to delete and then touch "Forget this network." Expect that some wireless networks detected by your iPod touch will ask you to sign up for a fee-based service. If this is acceptable to you, open up the Safari application from the home screen. You will be taken to a website that explains the terms of service and accepts credit card payments for wireless Internet access.
When the iPod touch was introduced in 2007, it quickly became one of the best-selling portable music players on the market. What separated the iPod touch from its competitors was its ability to access the Internet through Wi-Fi networks. If you're ready to surf the web and send e-mail with your new iPod touch, it's easy to get connected. Just a few taps, and you'll be on your way.
Tap the "Settings" icon on your iPod touch's home screen. Tap the arrow on the far right of the "Wi-Fi" bar on the "Settings" screen. Move the slider on the "Wi-Fi" bar to the "On" position. Move the slider on the "Ask to Join Networks" bar to the "On" position if you wish to be notified before your iPod touch connects to a new network. Moving the slider to the "Off" position means you must select a Wi-Fi network manually before your iPod touch will connect. Press the "Home" button to return to your iPod touch's home screen. You will see the Wi-Fi icon appear in the top left corner of your screen with up to four bars illuminated to indicate that Wi-Fi is available and to show its signal strength. iPod touch Support and ios support
Apr 18, 2013 | Apple iPod touch 3rd Generation MC086LL/A...
How Do I Unlock My Ipod Touch When It Says Its Disabled?
"1. Connect the iPod Touch
2. Press and hold sleep+home until the device reboots.
3. Keep holding until that "please connect me to iTunes"-screen appears
4. iTunes says something about having detected a touch in recovery mode. Allow it to do its thing.
If you get the -18 error, proceed:
5. Disconnect the iPod Touch
6. Close iTunes
7. Reconnect the iPod Touch
8. iTunes launches and shows message as in step 4, but this time, the recovery will work."
Hope this helps!
Aug 15, 2009 | Apple iPod touch
Sending Message Problem!!
touch the START menu on the top left of your screen, touch on MESSAGING, select SMS/MMS account by touching, that will take you to your inbox. then just touch the MENU on bottom right of screen and select NEW... then touch SMS. It will ask you to add contact 1st. then touch screen where text goes till curser appears then type either by keyboard buttons or middle bottom of screen if you touch a electronic version of keyboard will appear you can use stylis to type on screen keyboard. Then bottom left of screen hit SEND. message sent message will come on screen when msg sent.... Goodluck
Apr 10, 2009 | Sony Ericsson XPERIA X1 Smartphone
I have misplaced the recovery CD for Sharp Actius RD3D PC Notebook and I need to re-install the Operating System, so I requires Drivers for its hardware components, Also if possible an another official...
You do not need the CD to recover this laptop.
From the User Manual:
1. Turn on your computer. When the message <F2> to enter System Configuration
Utility appears on the bottom left of the screen, press F2. Then, the Setup Utility
will open.
2. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
3. In the Exit menu, confirm Exit Saving Changes is highlighted and press Enter
4. The system will restart. When the message Press F10 to Recover appears on the
screen, press F10.
5. Read the message on the screen, and select the way to recover your system; then,
press Enter. If you selected Formats hard disk and creates new partition, go to
the next step. Otherwise, go to Step 10.
6. Select the volume of C: drive and press Enter.
7. Read the message and select Continue; then, press Enter. The formatting and reinstallation
will start.
Although the pointer may be shown on the screen, never touch the
keyboard or the mouse during recovery except when the message prompts
you to. If you touch them, the re-installation will be canceled.
8. When the re-installation process is completed, the system will restart
9. Set up Windows XP by following the on-screen instructions. When you complete
the Windows setup, make sure to set date and time.
If you need help understanding these instructions, feel free to ask.
Jan 08, 2009 | Sharp Actius RD3D Notebook
How to install a new printer
1. install the driver that include in a package of printer
2. read and follow instruction in the installer cd
3. after installation of driver complete..connect the printer,pc will automatically detect it{new found hardware} and wait for the message{your new hardware are installed and ready to use}
in printing select the model of the printer connected and installed before you print.
Sep 17, 2008 | Computers & Internet
Open Questions:
Dryer is acting up. so, it hasnt been used in about 2 months.  it sat out in a cold garage.  but was back up to 'room temp' when we hooked it up.  the gas line is secure.  the venting is proper.  the dryer's level.   after turning it on, not much has happened.  a faint 'beeping' signal comes out of it every few seconds or so, and signal lasts about 2 secs.  the dryer will tumble and kinda gets a weak luke-warm.  i heard this clicking (blower motor i think) as if it were a rotating clicking noise.  then i heard what sounded like a piece of plastic drop.  then poof! the blower kicked on and the dryer started crankin'! working great.  thought maybe something needed to settle.   note* i did have this dryer on its side while moving it in the back of my pick-up truck.  (which was covered from the elements w/ a cap & laid on soft blankets).* after several uses some serious noises started coming out of it.  a severe clicking rotating plastic thumping, sounded like hard plastics banging, clicking rotating, hard to explain.. i reset the dryer.  now it starts up, and just rotates, blower never kicks on.  doesnt really get hot, back to a weak luke-warm.  (i threw a wet towel in there..nothing, no heat/blower)  nothing going through the vent either.  so..i was thinking about pulling the back off, but figured i'd ask you guys first. also, do you think it's worth it to call in a Sears professional?  costs involved?   yeah man, any help would be appreciated, the thing's out of warranty, and well..i need a working dryer, full household.  laundry piles up!   - thx, Angelo
Feb 28, 2017 | GE DPGT750GC Gas Dryer
GE DPGT750GC Gas Dryer Logo
510 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
