Question about Mitsubishi VS-5043 50" Rear Projection Television
Mits Big Screen TV model #VS-5043
Hey, while transportin gour TV the screen poped out How do we get it back in, nothing I've tried had worked and I wonderif there is a trick to it. Also will it work the same or is it done for.
    Genius:
  • 2,920 Answers
You have to take off the front framework to out the screen back in and it should still work
Posted on Aug 25, 2008
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mits rear projection VS-4543
i wouldahve the power supply checked out,,,it sounds like it may be getting weak
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-5043 television
dreamer714- You should be able to order from any tv repair shop,the price how ever will be rather high.I think the last one I ordered was about 400 or so, it depends.The unit itself is fairly easy to change. cooltekFeb.18/08
Feb 11, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-585R
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Dec 21, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Big Screen TV VS 5043
depending on the model it could be serveral things. it could be convergence ic's gone bad or a problem with the power supply, something is shuting it down . contact mitsubishi for your nearest sevicer
Oct 19, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi big screen tv
The VS5043 shuts down for many reasons. The most common are power supply issues. Bad caps, open resistors, shorted regulators, and missing voltages will cause the set to shutdown.
In my notesI have a location of components known to cause your problem( R5A03,L5A00,D5A21,Q5A04,Q5A03,C5A19,L902,IC900.IC700) All the parts listed are available. As I stated above there are many reasons for shutdown such as a bad flyback transformer that may not be available anymore. However, this type of failure needs to be properly diagnosed by a qualified technician. Good luck!
Sep 23, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Need help with analog cable not showing!
1. CHECK BASE BIAS VOLTAGE OF Q217, FOR 0 VDC (BIASED OFF) IF .7 VDC (BIASED ON) CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB
Aug 12, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Convergence Problem?
Convergence problems are what you have possibly a pincushion error. Either way if you have to have a repair shop do the repair, you should look at replacing the old TV.
Jan 26, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
