Toshiba tz50v61 blinking red light
Did yoy fix the problem. If so what did you do to reoair it? am having the same problem.
any help much appreciated.
Bart
bmolli@columbus.rr.com
  • abaker_08 Dec 07, 2008
    TV receives power, but will not show a picture, only a blinking red light.
  • Dale Bohne Oct 21, 2011
    how was this fixed
5 Suggested Answers
  • 6 Answers
SOURCE: Toshiba 65H81 blank screen and red blinking light....help
I don't think is any lamps.
If you are handy try to open the back of your tv, (unplug it first) don't touch anything just yet, you need to make sure you discharge any static left on the power board (the first from your left )Unplug power cord from the board. Take a heavy long screwdriver (Isolated) and lightly, touch a few parts on the board including the thick red wires that go to the lamps. Once that's done its time to put your dexterity at work. You need to lift that board (PD 0074) so that you can check some fuses like F850, F852, etc. for continuity. Mine were out. I had replaced those two and I had tv for another year. Remove the screws that hold the board. Now, this board PD0074 is connected to the next board by two white connectors and one blue. ....lift them up from one side with your finger nail. Don't unplug anything from the power board, just loose some wires so that you can lift the whole board on one edge. Get a voltmeter and set it to check continuity. Mine has a buzz. Look for them fuses if they are bad , ....replace them. (You can buy them at Partstore.com.....punch in "fuses"or "125V 2A")
In my case that was the only problem a year ago. Now I also have the same problem but this trick didn't work for me anymore. The Power Co,. messed me up big this time. In fact the problem with these Toshiba rear proj. is that when the power in your house goes out and comes back right a way in a split second and you don't have a power regulator, guess what : 'red led blinking'
In my case this time the whole power went on and off a few times within 10 sec. and by the time I got to the TV to unplug, it was to late. I think I have to replace the whole PD0074 board....and that's expensive.
Good luck
Posted on Mar 10, 2008
Maciso
  • 125 Answers
SOURCE: Toshiba TZ50V51 fix blinking red light
it took me a lot of time to understand the circuits on the toshiba they are not ease to fix but you may be able to get a tech for 300,00
Posted on Aug 23, 2008
SOURCE: toshiba blinking red light
MI TELEVISON PARPADEA LA LUZ ROJA Y SE MANTIENE EN ESTADO DE HINBERNACIóN
Posted on Sep 28, 2008
Slinteriors
  • 8617 Answers
SOURCE: Toshiba Projection Television TZ50V61, Red
That sounds like the deflection board. You can get the replacement deflection board from www.tvrepairworld.com under Toshiba Circuit Boards catagory
Posted on Jun 14, 2011
Toshiba Projection Television TZ50V61, Red power light blinks, no picture, no sound
Jun 14, 2011 | Toshiba TZ50V61 50" Rear Projection...
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
I have a Toshiba 36" tv Model # 36AF61. Recently
Unlikely to be a fuse, likely to be some capacitors and possibly semiconductors need changing in the power supply or line output section of the board.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Toshiba 36AF61 36" TV
I NEED MANUAL SERVICE TOSHIBA TZ50V61
Service manual of Toshiba TZ50V61 is available HERE for small fee.
Thanks.
Aug 17, 2009 | Toshiba Televison & Video
Toshiba big screen modle # tz50v61 , power light comes on but tv does not , light keeps blinking . when i try to power it up , light comes on and then starts to blink again . tv will not power up . VERY...
that sounds like it could either be a convergence issue, or power supply issue. If you go to the following link and leave them a email with your model number and symptoms they will help you identify which part you need.
http://servicemanuals.vstore.ca/
Apr 20, 2009 | Toshiba TZ50V61 50" Rear Projection...
Problem
with my projection tv , i have a Mitsubishi dlp, the screen went black and a red light flashed it was the bulb that had to replaced i dont know if that maybe your problem.
Aug 20, 2008 | Toshiba TZ50V61 50" Rear Projection...
Toshiba blinking red light
YUp i have the same prob 2 How can We fix it?
Jun 24, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba tz50v61 replacement protective screen
Andrews Electronics
www.andrewselectronics.com
25158 Avenue Stanford
Santa Clarita, CA 91355
  • Phone: (800) 274-4666
  • Fax: (800) 289-03
Apr 09, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba model tz50v61 convergence
need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Mar 16, 2008 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
Electro Med Services...
