Question about BenQ FP737S-D 17" LCD Monitor
BenQ fp737 monitor
Monitor is black, we turn the computer on and power button turns green but screen pls black the tower has been checked and the video card has been changed still noting on the monitor. can you pls help me.
thanks
  • Anonymous Oct 06, 2008
    Hello
    I have the same problem. Data cable and power calbe is OK. If I flash up on display with external lights I see a picture on display.
    Plece send me the answer to me to e mail cento@orangemail.sk.
    Thank you
  • alextrob Nov 19, 2008
    I have the same problem. It first happened with me after a power black out during a storm. I've tried the monitor on 2 computers with 2 totally different sets of cables so I'm thinking that it's a hardware problem. Nothing displays on the screen at all but the computer recognizes that the monitor is there and even detects what type of monitor it is.
    I realize I'm probably going to have to get my hands dirty and take the thing apart. Anyone have any good resources for repairing this monitor?
    Champion:
  • 220 Answers
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Posted on Aug 25, 2008
Brand new BenQ EW2730V not turning on after 30-40 minutes of use with the XBOX 360/PS3. Is it a feature or something because the power button is blinking orange?
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced
Oct 22, 2013 | BenQ EW2730V 27 WIDE
My Benq t221w monitors power light flashes green ond will not turn on, the screen stays black, sometimes it will turn on but noe it stays off.
It is an inverter issue, you can seek a replacement but it would be more cost effective to replace the unit.
Mar 14, 2011 | BenQ T221W 22 inch LCD Monitor
I have a benq fp71g model q7t4 computer monitor when i hit the power button the green indicator light comes on but goes right off i can hear a clicking sound when i hit the button what can i do
use another monitor with your pc to make sure your graphic card is working and
connect that benq monitor (to double check it is ok) another pc
find out if the clicking comes from the monitor or the pc tower,
if yes from the tower than your video card fails.
exchange it with another and replug benq monitor, boot up.that should solve the prob
Jul 28, 2009 | Computers & Internet
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Nov 01, 2008 | BenQ FP91G+ 19" LCD Monitor
BenQ FP737-D 17 Monitor
Hey... what you need it a new backlight inverter, your old one it busted...
Sep 14, 2008 | BenQ FP737S-D 17" LCD Monitor
BenQ FP737-D 17" LCD monitor
IT almost sounds if the monitor itself is overheating? Have you tried shutting the monitor off for 15 or so minutes then turning it back on? It may also be a video card overheating issue. Make sure your PC and Monitor both have adequate ventilation.
IF this doesn't help the situation, try updating the video drivers as well.
Sep 11, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq FP737 LCD Display
This is how the original Design logic works.You cannot change it.
Samir
May 12, 2008 | BenQ FP737S-D 17" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
223 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
