Question about Kenmore Elite 45986 Front Load Washer
Thank you!! Good Morning, F11 code cleared...now I have an F9 code. Can you help with this code? Of course I can't find my manual when I need it! Thank you so much for the fix it on F11.
  • 5,911 Answers
"F09" is a "Flood Condition" error code. The following link explains this:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
Read through the information thoroughly and verify all the recommended steps. More than likely you have a drainage issue with the drain pump as a possible culprit.
If you need to check the drain pump for obstructions, the next link explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Let me know if you require additional assistance. I hope this helps you.
PS All the fault codes are normally in a tech sheet provided by the manufacturer. This tech sheet is usually placed inside the washer behind the lower panel, or affixed to one of the interior cabinet walls.
Posted on Aug 28, 2008
I have kb-0817 gateway keyboard where can I find a pdf file owners manual for the keyboard?
Anything with an F on it has to be used in conjunction with the depression of the Fn key in unison. Anything else will be controlled by either the shift in unison or with the control key in unison with the desired key.
Nov 12, 2012 | Computers & Internet
MAYTAG OVEN SHOWING A F9 CODE. I PRESS THE CLEAR BUTTON, AND A FEW SECONDS LETTER THE CODE APPEARS AGAIN. WHAT IS CAUSING THIS CODE. OVEN WAS USED EARLIER AND HEATED JUST FINE.
Hi rosebud1239,
The F9 fault code error description is about the door latch. Please check the door latch components.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MGS5770 Gas Kitchen Range
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Jan 05, 2011 | Microsoft Office Computers & Internet
Hi, my GE Profile Mod# JBP90GV2BB S/N ZM223214G began beeping this morning and posted an F9 code in the display. The stove hasn't been used in 2 days. What does the F9 code indicate and what ccan I do to...
F9-- Failed Lock switch detected.
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
If the wires are ok and, the switch is not stuck, replace it asap.
Jul 10, 2009 | GE Profile JTP18 Electric Single Oven
F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Apr 09, 2009 | Kitchen Ranges
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
I CANNOT TURN OFF THE "LOC" MESSAGE
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (a couple of hours). Of course doing a hard reset erases all glitches as well as user settings and configurations, the unit will revert back to factory default 9assuming no hardware fault).
Maytag Error Codes:
LOC - this means configuration setting changes will not be allowed F9-1 Latch lock upper F9-2 Latch unlock upper F9-3 Latch lock lower F9-5 Latch unlock lower F9-6 Latch both lower
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jun 27, 2008 | Maytag MER6769 Gemini Electric Kitchen...
AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
166 people viewed this question
Sal De
fordexpert
Robert Rankin
