Question about Panasonic SV-AS10 Digital Camera
Play back and record
Can I play back material on, or record from, an external device, like a TV or monitor?
    Master:
  • 903 Answers
The SV-AV100 and the SV-AV50 come with an A/V cradle that allows you to connect to external devices for recording and playback. The SV-AS10 and SV-AV25 are not equipped for this operation.
Posted on Sep 01, 2005
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
My Sanyo LCD 40XR10F TV does not recongnise any mp4 movies i have on my external hardrive or usb stick?? Does it matter what size usb disk/drive/how many files are stored on them for it to play them?
Before you loaded the hard drive, and USB did you run a "Check File System" through the TV? These devices in order to use the "Time Shift Function", have to have pass with "SUCCESS", displayed on the screen. If not the TV will format a 4GB FAT32 filing system for you. The reason your MP4's might not work might be due to a firmware update that no longer supports MP4. You should have been OK if you recorded the material from the TV. Items you record from the TV will not play on any other device. Using the FAT32 format only allows 4GB but, the TV allow 8GB and a external device can be FAT32 format to 8GB. 8GB is only 2 hours of viewing time. So that should give you some idea how little the amount of files can be handled.
Dec 21, 2010 | Sanyo Televison & Video
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
Playback on external device.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Sep 01, 2005 | Panasonic SV-AV50S Digital Camera
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
Sep 01, 2005 | Panasonic SV-AV10 e-wear Digital Camera
Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
Play back, record from
Aug 31, 2005 | Panasonic D-Snap SV-AV100 Digital Camera
Panasonic SV-AS10 Digital Camera Logo
Top Panasonic Cameras Experts
skyblue007
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
