Question about Garmin (010-00583-00) for nuvi 750/760/770
Can't unlock maps
Following a link up to the Garmin website my nuvi 770 has decided not to show maps. I have tried to unlock the maps as instructed by that website, but have been unsuccessful so far. Any ideas will be gratefully received.
Frank.
  • FrankG6838 Sep 15, 2008
    Thanks I sorted it out by managing to contact the Support Desk, they emailed me two new files, which resolved the matter.
    FrankG6838
  • ricsms Nov 21, 2008
    I have the same problem ,, I thought it was the map updates needed to be updateed so I went to the Garmin website .. I downloaded teh latest System updates 420 - once the loader started it went throught the configuration then it came up with file corrupted -- now When I turn on the NUVI 770 it just displays system software missing.. and now I cannot find it as a drive attached to my computer -- like its just disappeared,,
    If this is how the software upgrade is supposed to work I am not pleased.. also now when I contact the Garmin website it says system dowloaded file corrupted -- or -- unable to connect to garmin website???
    If this is their solution thes the Nuvi is a piece of ****!!!!
    I do not understand why the loader would wipe out the system software on the device..
    any help would be appreciated..
    thank you
    rc
    Problem Solver:
  • 7 Answers
What have you tried? without knowing anything else, one suggestion is to make sure you are using the correct unlock key number. There are at least three numbers located on the disk.
Posted on Sep 15, 2008
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Have city navigator nt on memory card in nuvi 200.When booting up get a loading stripe followed by can`t unlock maps page with ok button which puts into normal screen.Is there any trick to reading the...
sir,
we used the serial number to register on web site.
they are very helpful garmin phone is
Hours of Operation
* Monday - Friday
* 8 a.m. - 7 p.m.
* Central time (closed holidays)
Phone
* 1-800-800-1020 (U.S.)
* 1-866-429-9296 (Canada) or (913) 397-8200
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
thanks
good luck
Aug 30, 2008 | Garmin GPS
Anyone - I purchased 5 garmin nuvi 550s - fresh out of the box all require system updates before you can do a map update.... 4 of 5 no issue.... #5 failed during system update and now i get te error that...
If the unit will connect to your computer you can try copying all files from one GPS to the other. Just be sure not to copy over the *.UNL file. That contains the unlock information for that specific device. This may get the unit running. If you get the error can not unlock maps after doing this try updating the map again. If the above fails please call Garmin for assistance. 1.800.800.1020
Jul 11, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
I have a Nuvi 770. The map update notice comes up after power up and the OK button shows but is not active. Cannot get by the screen.
I would try to fix it by doing a reset. Hold the off switch for over 8 secs. and see if it helps. Connect to your computer and download the latest software and maps.
Auragal
Oct 17, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin 750 cant unlock maps
Map unlock codes are specific to each unit. You will need to contact Garmin to obtain a code to unlock the maps.
Jul 10, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
I have a Garmin Nuvi 770 that won't "speak" when navigating
Frequently (about 20% of the time) when I have my Nuvi 770 plugged in, in the car and I turn it on, it gets stuck at the start up screen where it says, “Loading maps” I wait several minutes and it never completes. Then I turn it off and turn it back on and it comes right up, but with no voice. When I go to Tools > Setup > Language it shows no language and I cannot select one. I have to plug my Nuvi 770 into the computer, run web updater, it detects that I already have the software loaded and I select the option to download it again. When it has completed, I unplug the Nuvi and then go to Tools > Setup > Language and select American English.
Mar 22, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
I have a problem with Garmin 770 maps unlock
How to unlock this mapping to your Nuvi 700 series, if you get the error message “can’t unlock maps”
Please connect the Nuvi to the computer then follow the following steps:
1. Go to ‘My Computer’ and select your Nuvi.
2. Once you have selected the Nuvi go to the ‘Garmin’ folder.
3. Click options along the top toolbar of the open window, then select folder options.
Once the box appears, select the VIEW tab along the top and un-tick the ‘Hide extensions for known file types’, then click OK.
4. Once you are back in the Garmin window you will need to right click the window and
then choose NEW > Text Document:
5. Once you have the Text Document appear in the window you will need to name it:
gmapprom.unl (you may need to remove the .TXT extension).
6. Once the file has been created, right click on it and choose open. A window will pop
up asking you to choose the program to open the gmapprom.unl file, you will need to
choose NOTEPAD and make sure the box at the bottom that says to always use this
program for this file type is un-ticked and then click OK
7. You will then have an empty document open, in here you need to type your 25 character unlock code all in lowercase and without spaces or ‘-‘. After entering this,
save and close the document.
8. You can then unplug your unit and the mapping will be unlocked on the Nuvi. (Please note that if you have a Nuvi 770 then you will need to repeat this process again as you will have two unlock codes. You will need to name the second file
Jul 11, 2008 | GPS
GPS MAP QUESTION
No, Garmin will not provide map updates for free. You can update the unit's firmware for free from Garmin's website, but if you need new maps you must purchase them and download them into the unit. It should not be necessary to do this right away, though. Even if the unit does not have 2008 maps on it, unless there are major changes to the areas you travel most, it should get you around fine until you do decide to purchase updates.
Mar 26, 2008 | GPS
Garmin (010-00583-00) for nuvi 750/760/770 Logo
820 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
