Question about Philips HTS-3565 Theater System
HDMI issue I am having problems with the hdmi connection initially it will work but after puting it on stand by and turning it again, audio is not coming out from the speakers, but video is present in our LCD TV. For the moment, temporary solution is to pull out the hdmi cable from lcd and use s-video or composite connection, in order for audio to work. After which insert back hdmi. Hopefully, there will be a solution to this. Also, I have already upgraded the firmware, but still the same problem.
    Problem Solver:
  • 7 Answers
Turn the tv on first. then activate your other device. when your device is activated it sends a signal to your tv saying use this input. Hope this works.
Posted on Dec 11, 2012
  • 2,071 Answers
Pioneer vsx521 stopped recognising hdmi connection from computer
Press the Audio Parameter button (Looks like an x) then scroll up until you see 'HDMI AMP' and hit over to the left or right so it shows 'HDMI THRU' the HDMI will redo the handshake and you should have sound.
Mar 12, 2017 | Pioneer Audio Players & Recorders
Cant get our HDMI to work on our JVC HD 58S998.
First, contrary to popular opinion, HDMI cables connect to a tv are not the best way to connect the two. The HDMI technology has flaws that often shows up as sound problems.
If your TV has the capability for component connections, use them. It will take 5 cables, 3 for video and 2 for audio. You will get superior sound and video. The 5 cables terminate in RCA type connectors and are much cheaper than an HDMI cable.
I hope this helps and solves your problem. :-)
Jan 03, 2010 | JVC Televison & Video
Denon AVR-2307CI HDMI won't always connect
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
Aug 23, 2009 | Denon AVR-2307 Receiver
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
PS3 80Gb can not connect to Infocus X10 via HDMI
it is not your hard drive
you have to reset the video setting and it will work again Hdmi is different on each tv so you have set this up again ok let's do this with the unit off turn the main switch on the back of the unit connect your Hdmi cable to your tv now place your finger on the front on/off switch keep your finger there ok now turn the mainswitch on the back of the unit the playstation turns on but don't remove your finget yet wait about 4 seconds or until your heard another bip (not the one when the playstation turns on) once you heard this bip remove your finger before the playstation turns off if you let it turn off try again all of this but if you remove your finger on time just wait few more seconds and bingo you have picture again using Hdmi
Mar 10, 2009 | Sony Playstation 3 (PS3) Console
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
HK AVR 645 7.1-Receiver Turns off when sound starts to come through
did you figure it out? I bet your problem is the same as mine NOT HDCP complitant.... its gettting a signal from the bluray that can not be accepted... research HDCP compliant... my ONKYO does the same thing...
Jul 10, 2008 | Harman Kardon AVR 630 Receiver
Hi' I have a Denon 3910 that is connected to an Infocus Projector via HDMI out on the Denon to DVI on the Infocus(One end of the lead is HDMI the other DVI) .problem has always been without the projector...
You can try this reset method, if it doesn't work it will probably need service by a professional. Remeber that all setting will be lost, make sure you know them so you can put them back in after you are finished.
At the player stop condition,
press 3 buttons for DVD operation
(“PLAY”,”OPEN/CLOSE”, and “ SKIP”) until
“INITIALIZE” appears and disappears in the display.
(“Initialized” appears and disappears on the TV screen.)
******All user setting will be lost and its factory setting will be
restored when this initialization is made. Be sure to memorize
your setting for restoring again after the initialization
Jul 03, 2008 | Denon Audio Players & Recorders
White lines, images on screen turn funny colors, audio humming
Hi :)
I had small white dots appear on the dashboard screen, like static... I am using an HDMI connection.
Make sure that your cables are connected correctly...
Try going to the display settings and selecting the automatic setup for HDMI, that worked for me, it looks pefect now..
my problem is that discs are not loading(but that's a different issue)..
It might work the same way if you're not using HDMI.. just select your connection again, or change connection settings and back again. But make sure that you select the correct settings if you want it to display correctly.
I hope that helps, good luck.
Jun 11, 2008 | Sony Playstation 3 (PS3) Console
Sony bravia intermittent sound
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Feb 20, 2008 | Sony BRAVIA KDL52XBR2 Television
Philips HTS-3565 Theater System Logo
218 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
