Question about Motion Computing LE1600 Tablet PC
Glass replacement did you figure out your glass replacement? i have an LE1600 that needs similar care.
  • 3 Answers
A replacement display can be purchased from some sources for around $600 but you'll find that now an off-lease LE1600 can be purchased for less than that. With all the time to replace the display (about an hour for an experienced tech) I would consider buying another used unit and moving your hard drive to that rather than try and get the glass replaced.
John Hill
Posted on Mar 04, 2009
Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
Apr 05, 2012 | Motion Computing LE1600 Tablet PC
How do you repair a cracked screen?
I don't own one, but I'm guessing it has a glass-like layer over an LCD display. The first step would be to figure out if it is the glass that is cracked, which I'm assuming is the case, or if the LCD is what is broken. In either case you will need to find a replacement part. I've had good luck using or eBay to find similar replacement parts. Just search for your devices model number plus screen. After you have the part you need it should be a simple disassemble, replace, reassemble procedure. Hope this helps.
May 10, 2011 | PANDIGITAL Digital Book 843967071153...
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
Hi .I am trying to Install WIN 7 on LE1600 from the USB (Enabled with Bootable Win7).I am able to boot from the USB but stucking at giving the Inputs for Regional seting at Installtion as the KEYBoard is...
As far as I am aware windows 7 has not been confirmed for tablets or win CE platform type devices
Check you manuals and any Cd's that came with the 1600 and see if there is some form of reset or original system restore ability.
Microsoft has a win7 compatibility check utility anyone wishing to try win 7 on these types of device is recommended to use that first to identify potential issues.
Sep 11, 2009 | Motion Computing LE1600 Tablet PC
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
Have motion tablet pc 1600 , suddenly when starting up get "problem or unable to load operating system"
It could be one of several problems:
1. Bad hard drive (reasonable likely depending on age); does the hard drive make noise or spin?
2. Loose hard drive cable (less likely)
3. Virus (likely)
If it doesn't boot at all you can open up the back and make sure the hard drive is "seated" properly - that means all the connections are firmly in place. If that doesn't take care of it you will have to try and reinstall the OS.
John Hill
Mar 01, 2009 | Motion Computing LE1600 Tablet PC
Slow not responsive Motion computing LE1600 tablet pc
Do you have a lot of extra programs running in the background? These are great devices, but they do not have a lot of processing power or memory. Try cleaning up unnecessary programs to see if that makes a difference.
The sure fire way to make sure there isnt anything running is a reformat. Just make sure you backup your data first.
Dec 20, 2008 | Motion Computing LE1600 Tablet PC
Power port on le1600 does not charge batteries.
In some Motion LE1600 tablet pcs, the AC adapter port becomes separated from the motherboard. It will charge in the convertible keyboard or docking station because the power comes from the USB connection (for the kb) or the dock connector (for the FlexDock). Motion used to fix this by repairing the solder joint but now they just replace the motherboard (very expensive). There are ways to solder this but the repair doesn't always last unless you have someone really good do it.
Oct 24, 2008 | Motion Computing LE1600 Tablet PC
Motion Computing LE1600 Tablet PC Logo
475 people viewed this question
Top Motion Computing Tablets & eReaders Experts
Chris Larocque
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
