Question about Packard Bell Computers & Internet
Trying to upgrade packard bell pc 133 edo ram which have 128 mb to a 512mb, a new pc i bought in 2001, atb this precise moment i cannot find this memory in local shops because of age, do you know where i can find memory for it or any other solutions thanks
  • 300 Answers
Use this link it should help you.
NOTE: Just make sure that EDO is the type of memory that you need. You can also find other types of RAM there.
Posted on Aug 25, 2008
RAM upgrade on Packard Bell Columbia mainboard
you can only use as much as the motherboard are made for.
May 01, 2013 | Computers & Internet
Cannot find specification for packard bell i start 1379. I want to look into the possibility of upgrading this pc. Can anyone point me in the direction of the specs being available online for this...
Here is the homepage:
This specs provided was complete with a Intel Intel Serial ATA-300 ATA-133 PCI 160 GB Microsoft Windows Vista Home Basic , ATI Radeon Xpress 1100 128 MB 4 MB . The Desktops memory add up to 2048 MB , with standard memory 512 MB , memory installed 533 Mhz DDR2 SDRAM DIMM 240-pin Very low profile PC4300 Compact Flash Type I with 2 Expansion Sockets/Slots.
You can update the graphic, by adding a better graphic card, on the mainboard.
The ram can be upgraded to 2 gb ddr2 ram.
A bigger harddrive, can be added, for more space.
The cpu will be hard to find, it probably have socket 775, but this cpu is not available anymore.
And not all cpu`s will fit the mainboard.
Good luck
Feb 10, 2013 | Packard Bell (181368) Motherboard
How to install upgrade sdram 128 pc133 for gateway 500
PC 133 Max ram for your model is 512MB - two 256 Memory sticks. Open the case, remove the menory in there (one clips on the side of each module) take note of the way the module comes out - replace with your new ones - reboot and that should be that.
May 10, 2010 | Gateway Essential 500 PC Desktop
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Hi Guys I have a packard bell istart 1359, memory max is 2048mb and I currently have 512mb installed. I purchased 2 x 1gb ddr2 pc2-5300 -cl=5 -unbuffered -non ecc ddr2 - 667-1.8v -128 meg from crutial. I...
some systems require ECC it may be as simple as obtaining ECC Ram......u can try checking the memory that cam with it to see whether it is buffered and ECC if it is you will have to obtain same type of RAM
Apr 15, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Want to upgrade ram pc2700 128mb to 512 mb , so i purchased a 512mb ddr1 400mz ram and put it in parallel port but my computer does not boot so i remove the 512 mb ram but problem was as it is now what...
first you check that your ram version.... i means it is compatible with your motherboard...if still prob remains then remove your all ram insert 128 mb ram then restart the system....... upgrade ram should fallow frequency of 512 mb RAM are same as 128 mb ram freqency........if mismatch is occured then it did nt wrked correctly...
Mar 30, 2009 | Computers & Internet
Ram change on Packard Bell easyone 2120
Memory Upgrade Instructions
128 MB SDRAM on-board, max. 256 MB upgrade (384 MB total), PC-133
Remove the memory module according to these steps:
1. Turn off system power.
2. Remove the battery and disconnect the AC-adapter.
3. Open the top cover.
4. Press the locking latch downward to unlatch the Easy Start panel.
5. Then push it leftward and lift it up from the left side.
6. Slightly lift up the keyboard and disconnect the cable from the system board to free the keyboard.
7. Pull the retaining clips outwards (1) and remove the SO-DIMM module.
Keith Stoffer
Comptia A+ Certified Technician (20+ years)
Oct 30, 2008 | Packard Bell Easy One Silver 2120 Notebook
Memory upgrade
Yes you can get 4 sticks of 256MB of RAM or get 2 sticks of 512MB that will work fine on your computer....
Jun 02, 2008 | Generic Memory OD-IEA-100 ETHERNET UPGRADE...
Ram Question
how old is it ? It;s possible that the total amount of memory that it supports is of 256MB
It should not matter the fact that the memorys on the slots have different sises
But u have to check u're user manual, it contains all the info. u need....
Also u can try a BIOS update ....
Jan 19, 2008 | Itronix GoBook IX250 Notebook
Computers & Internet Logo
89 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
