Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
My macbook wont start. you can hear it begin to boot up but then everything stops and the white light flashes rapidly
Try keeping the powerbutton down for several seconds till it reboots. Usually works.
Posted on Nov 05, 2008
Macbook A1278 Flashing ? on Boot up
Bad Hard Drive or the computer can't locate a valid operating system. Have a tech look at it.
Dec 12, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Wont boot up. Just beeps every 5 seconds and a
Is the beep a moderately high tone that lasts for about two seconds? If so, this is the firmware loading signal, which sounds only when the power button is held in on powerup. This would indicate that your power switch has a mechanical or electrical problem and is not releasing.
If this is not what you are hearing, please provide more detail.
Jun 18, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Flashing ? tried everything then installed new HD however now the macbook keeps ejecting the install CD before anything happens onscreen cant hear fan and superdrive making slightly grating noises . any...
Try the following: 1. Reset the powermanager by pulling the battery and holding down the power switch for 5 seconds than wait a few more seconds reinstall the battery and plug in your power supply. Push the start button. You can watch the light on the magsafe adapter to confirm that the power manager resets. 2.If you still do not boot to the CD try booting while holding down the C or the option key. 3.If you still do not boot up and have a second mac: try booting into target disc mode connect to the other mac with a firewire cable and install your software on the hard drive remotely. Good luck
Sep 03, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Aluminum Macbook has flashing file folder with ?, won't start
Sounds like someone spilled windex on it. You may be out of luck if it ran down and hit the electronics. (which it sounds like it did)
Aug 14, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Boot macbook problem
Parallels won't have caused this, Bootxchanger might have but it's not likely. More likely is that you HD is faulty.
A largish number of white Macbooks shipped with faulty Seagate HD which, although fine to start with, started failing after about 1 year of use.
I've seen 3 in the last six months.
Thankfully the HDs in these MacBooks can be changed in just a couple of minutes, the bad news is that the data on the drive is generallycompletely destroyed.
Try starting up from your install DVD, but not do the install. After you get asked about language, at the next screen, go up to the menu bar and locate disk first aid. Run that - you may be lucky and it fixes it or you may not.
Apr 28, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Random Flashes on Macbook 13" native screen
you could try reseting the pram. this is accomplished by holding down Command, Option, P, and R at startup you will want to hear the start up tones at least three times. if that doesnt work you might have an inverter issue, the inverter is located behind the screen and needs to be looked at by a pro
Jan 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Guitar hero world tour for ps3
i had the same problem but with trial and error i came up with a soulution
1. Turn on the Playstation 3
2. Plug the dongle for the drum set into an open port on the PS3, the light will begin to flash slowly.
3. Hold down the button (where the light is flashing) on the dongle until it begin flashing very rapidly. Release the button and the light continues to flash rapidly.
4. Hold down the PS button on the drum set until the red light starts flashing rapidly.
5. Within a few seconds you will get a solid light on both the Guitar Hero World Tour Drum Set and the Playstation 3.
thanks
Jan 04, 2009 | Video Game Consoles & Games
Flashing brake light
Check the Earth cable in the boot see that it's clean no white bits around the connection or the join. Cheers, Malcolm Campbell.
Apr 18, 2017 | 2000 Lexus RX 300
Apple Remote Not Working
Have you installed anything in between time? (i.e.,Software updates, 3rd party drivers.) Have you cleaned or organized your hd and "got rid of things you don't use/need ?" Has the laptop been serviced or opened?
Try resetting the MacBook's PMU (power management, hold down power button while the battery is out and the cord is unplugged) and possibly resetting the PRAM (hold down command + option + p + r before you hear the startup chime, it should start again, let it boot from there).
Sep 02, 2008 | Apple MacBook Mac Notebook
Flashing Folder
you are having main-board issues and possible harddrive issue.
but the mainboard can cause drive failures your info might be fine,The blue screen indicates a board error(memory usually)
Aug 09, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
162 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
