Question about Datacard Group SP75 Color Card Printer
Datacard SP 75 plus printer technical manual
I would like an online manual for datacard SP 75 plus printer urgently.
  • 36 Answers
Contact tulsabiz.net
Posted on Mar 19, 2010
Why is my printing off?
There are too many reasons, computer, drivers, ink, connectors etc Is the computer seeing it ok? Is it loaded correctly? Is it online? etc
here's a site which will help you.
SP75 Plus Card Printer Support
May 16, 2014 | Datacard SP75 Plus Card Printer
Datacard error PR 01739
Upgrade the printer firmware (Go Green firmware update) as you are likely using the newer eco friendly ribbons. The older firmware versions do not recognize this ribbon, which leads to the PR01739 error.
Download firmware here: https://www.datacard.com/id-card-printer-support-and-drivers/sp55-plus-card-printer
Dec 02, 2012 | Datacard SP55 Plus Printer
I have a Datacard SP55 plus and recently I started to get two white lines on the id card that I am printing and it goes right through the persons name so it is very noticeable I am not sure how to fix...
You have a physically damaged print-head.
The print head is in the cover and us user replaceable by pressing the lever inside the cover.
Print heads are considered consumables and need to replaced at maintenance. You can contact Datacard at there web site and they can have someone come out and change for, as well as service the printer. Or you can buy one online about $550 and change your self.
Apr 23, 2010 | Datacard SP55 Printer
I need Mac driver for Datacard SP35 Plus printer
There is no Driver from Datacard for Mac, windows only, you may possibly be able to use opencard format but SP35 does not support opencard
Mar 14, 2010 | Datacard SP35 Printer
Want to clean using the cleaning card.how do i do it -data card sp 35plus
You can't - the Cleaning Card supplied with the replacement ribbons is for other models of the Datacard printer, not the SP35 Plus :(
Jan 22, 2010 | Datacard SP35 Plus Printer
Am trying to install Datacard sp35 plus card printer driver on windows 7. It says it cannot see usb connection. When i installed it on windows xp, it worked fine
Make sure you have the driver available. Then click on the "add a device" under the hardware and sound tab. Windows should start looking for connected devices and find the Datacard. Then when it starts to install it windows will ask for the driver location. Now the problem is windows 7 is so new that there might not be a driver available for it to run the datacard and the windows xp driver might not work. So also check the manufacturer's website for a updated driver.
Nov 11, 2009 | Datacard SP35 Plus Printer
SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
www.TulsaBiz.net
Apr 07, 2009 | Datacard SP55 Plus Printer
Datacard Group SP75 Color Card Printer Logo
1,264 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
