Question about Nintendo Pokemon Emerald for Game Boy Advance
Pokemon Emerald i can't enter the secret dungeon?
  • Anonymous Aug 26, 2008
    where and how can i catch the three regi brothes
  • kelvin123456 Sep 27, 2008
    mingames.com
  • 28 Answers
EMERALD ONLY! REGI GUIDE! EVERYTHING you need and how to do it:
1) Relicanth, 2) Wailord, 3) Dive, 4) Surf, 5) Rock Smash, 6) Dig, 7) Flash, 8) Fly*
(BRING 60+ Ultra Balls/ 30+ Timer Balls/ Pokemon levels 40-47 with Status effects like: Sleep/Paralyze)
1) Relicanth is found only underwater outside Sootopolis City (Route 126 is the best, 124 is the only other option)
2) Wailmer is found by fishing with a Super Rod on Route 129. You will get the Super Rod from a sailor living near the Space Center in Mossdeep. Surf and while surfing, use the rod. You may not get a Wailmer on the first try but keep on trying. When you get the Wailmer, evolve it. It evolves at Level 40. If it is already at Lv. 40 or over, evolve it one more level and it will evolve. It's pretty common outside of Lillycove City.
3 - 5) You must have had these to get through the game.
6) Dig. There is only one dig TM in the game. It is given to you by a girl in Route 114. Just off Fallabor Town. She is next to a cave inside her house. She says that her brother is the Fossil Maniac and she gives you the TM Dig. Dig, is a TM. Dig can only be used once,. You can still get dig elsewhere; Trapinch learns Dig at level 41 and Nincada at level 45. Or trade a Diglett from Diglett's Cave from FireRed/LeafGreen.
7) Flash is not optional. You MUST have it to unlock Registeel. Without it, you can still unlock the other two, but, you need it to unlock Registeel.
8) Fly is optional. But, without it you would have to Surf to everywhere you want to go. It is highly recommended.
Onward to the Regi's!
REMEMBER: If you happen to mess up, no biggy, fly back to Pacilog Town and try again.
First, fly to Pacifilog Town, Surf west, go NEAR the currents but NOT in them, yet. What we're trying to do is to stay as low as possible to the currents. Go to the lowest point, and start surfing. If done correctly, you will now be facing a fisherman. If not previously done, he will challange you to a battle. Defeat him and walk down, to the lowest point and surf. If done correctly, you will be facing a pair of swimmers. Go past them and touch the very lowest part of the current. You will land on a shallow part of Water. From here, go to the lowest part and go again.
From here, you will be taken to a shallow part of Water. Notice; part is on Route 133, part is on Route 134. Once here, walk to the left as much as possible (without leaving the shallow Water) and then walk down as much as possible. You will now be at the bottom-left-hand corner. Take two steps forward, turn left and surf. If properly calculated, you will now be in currents, the currents will then take you to a patch of still Water where you can dive. When you dive, go through the cave, you will still be underwater. Follow the path and you will arrive at a rock engraved with braille. When translated, the braille reads; GO UP HERE. Be on this exact spot and surface. If done accordingly, you will now be in the sealed Chamber.
In here, you will find ten rocks all engraved with braille. Go to the back of the chamber, the braille reads; DIG HERE. Use the Pokemon that has Dig and Dig there. A path to another room will open up. In this room, there are six stones, they read;
1) IN THIS CAVE WE HAVE LIVED.
2) WE OWE ALL TO Pokemon.
3) BUT, WE SEALED THE Pokemon AWAY.
4) WE FEARED IT.
5) THOSE WITH COURAGE, THOSE WITH HOPE.
6) OPEN A DOOR. AN ETERNAL Pokemon AWAITS.
Go to the back of the room. More braille. It reads; FIRST COMES WAILORD, LAST COMES RELICANTH. Put Wailord first in your party, and put Relicanth last. Well, that's it. If you've done as said, the doors would have opened. Exit the cave.
REGIROCK,
ABILITY; CLEAR BODY (Prevents ability reduction)
Met at Lv. 40, in DESERT RUINS.
Moves: CURSE, SUPERPOWER, ANCIENTPOWER, ROCK THROW
Fly to Lavaridge Town, go west (right) until you meet the desert. Go in. To the bottom of the desert, you will see a rock with an opening. go in. . Go to the back of the cave and read the braille. From the braille, walk exactly like this;
LEFT, LEFT, DOWN, DOWN, THEN USE ROCK SMASH.
If you've done it correctly, a new opening will be revealed at the back of the cave. Go in. SAVE! Do not use your Masterball. Do not kill it. Capture it... NEXT!
REGICE
Met at Lv. 40, in ISLAND CAVE
Moves: ICY WIND, CURSE, SUPERPOWER, ANCIENTPOWER.
Fly to Petalburg City. Go west of the city and use surf. Stay to the left and you will come to some trees, land go around the trees, continue going down and you will find the cave. The braille at the back reads: STAY CLOSE TO THE WALL. RUN AROUND ONE LAP.
So, in any direction, RUN around the cave without leaving the wall. If done correctly, the opening will be revealed. Go in. SAVE! Capture. Do not use your Masterball. Do not kill it!
Last one! REGISTEEL!
Met at Lv. 40, in ANCIENT TOMB
Moves: METAL CLAW, CURSE, SUPERPOWER, ANCIENTPOWER.
Here is where you need Flash. Fly to Lilycove. Go to the west. Continue going west for a longish while until you can no longer go. Go up the stairs, through the really tall Grass, up the stairs again. Guess what? Go to the back of the room. The braille reads:
THOSE WHO INHERIT OUR WILL, SHINE IN THE MIDDLE. Walk four steps back and use flash. Go in. SAVE! Capture. Do not use your Masterball. Do not kill it
Posted on Aug 29, 2008
Haw to downlowd pokeman emerald
Posted on Jan 16, 2009
  • 50 Answers
QWERTYUIOPASDFGHJKLZXCVBNM
WATCH YOUTUBE
Posted on Apr 30, 2009
Yo you need to catch all the legendary pokemon in emerald yo
Posted on Oct 12, 2008
    Problem Solver:
  • 6 Answers
You first go to pacifilog town then go down the rapids some where in the rapids is a diving spot go down in it go to the rock read the brail then in front of the brail use dive then you will resurface in a secret chamber go to the very top of the chamber read that brail then use dig in front of it then go inside read the brail in there it should say wailord at front and the other name which i dont remember right now so then you do that go to the ruins in the desert the ruins in route 120 and the ruins on route 124 thats that
Posted on Jul 30, 2009
Wer can i download this game for my GBA emulator? please help
Posted on Aug 31, 2008
You can't enter pokemon dungeon because yo haven't fight with the other trainer
Posted on Dec 08, 2008
Aronjusting
Posted on Sep 20, 2008
Pokemon
Posted on Nov 21, 2008
How to download pokemon emerald on pc
Download (visual boy advance) from (vba.ngemu.com)
then download pokemon emerald rom from (http://www.mxemu.com/romshare.php)
and you get pokemon emerald version in pc.
Aug 03, 2010 | Nintendo Pokemon Emerald for Game Boy...
Pokemon emerald data lost says it is corrupt or damaged
it's not possible to get back the saved file..... for some reason that happens a lot on ds/ds lites..... there is nothing wrong with the emerald game. try playing emerald on a GBA.
Dec 28, 2009 | Nintendo Pokemon Emerald for Game Boy...
What he said
if its curupted there is no fixing it
Sep 12, 2009 | Nintendo Pokemon Emerald for Game Boy...
I cant go the wish cave 99 floor.because im level 1!what pokemon that i used to finish this dungeon !
Save ur money and go to the Kecleon shop and buy those level up things. Bring the m into the dungeon
Feb 20, 2009 | Nintendo Pokemon Emerald for Game Boy...
DS cannot load
hmm pokemon emerald ,perla ,mystery dungeon,red rescue team ,diamond,and pokemon ranger
Sep 05, 2008 | Nintendo DS Lite Console
Nintendo Pokemon Emerald for Game Boy Advance Logo
1,047 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
