Question about NAD C541 CD Player
NAD C541 CD Player
Since the early beginning after purchase, my NAD C541 jumped both with CD and CD-R. It's a HDCD that, for other respects, sounds very well. I'm very upset with NAD for the zero-value technical service, at least in Italy. After 2 months they gave me back my C541 with the old and new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists? Is there a chance to make some useful modding/tweekening?
Thank you
Marcello
mcl.vlb@tiscali.it
  • timaxdestr Apr 14, 2009
    My NAD C 541 i has the same problem with a slipping belt. Where do I get a new one?
    Greetings, Timax
    Genius:
  • 1,175 Answers
I wouldnt buy another one from NAD.
I've worked on their stuff cant say anything nice, Sorry.
Posted on Nov 14, 2008
  • 2,071 Answers
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Regards,
VOTIT
Posted on Aug 25, 2008
Hi, I have a NAD C541i cd player when i turn it on i get three blue line on the display, i open the draw and insert a CD disc but the blue lines stay on the display and the disc don't play. can you...
The blue lines you mention should flash when trying to find
the 'Table of Contents' of your CD, even if a CD isn't loaded.
If when a CD is loaded and these lines flash for a while without
any CD info e.g track no. / disc length then it's more likely that a problem has occurred with the laser.
Various NAD CD players use the Sony KSS-213 Laser unit
and for some reason particularly with NAD CD players, they tend
to drift out of calibration over time so what i usually do when i come across this is very finely adjust the pot trim on the laser itself and testing a CD between adjustments.
Jun 22, 2011 | NAD C541 CD Player
Second hand NAD player worked well at test. Arrived at home no reaction when power on. Led turns first green, then orange. Doesn't react at all...
If it's the C541i version then there should be a switch on the rear of the
unit.
Flick this switch and all should be fine.
I think it's something to do with interconnecting other NAD products
why this switch is used.
Jun 03, 2011 | NAD C541 CD Player
On loading a cd in to my C 541 it seems to freeze, indicates 'no disc' and makes a clicking/whirring sound. Will not play anything at that point. This happens with genuine, bought CDs
Seems that your player is looking for the index on your CD.
You can try to clean the laser carefully.
If your not familiar to do that, ask somebody.
Regards Gerard
Mar 08, 2011 | NAD C541 CD Player
Dont play,the tray dont work
Please check the mechanism on its motor and gears for malfunction. Please get it repaired or replaced if defective.
Feb 06, 2011 | NAD C541 CD Player
NAD C541 tray does not open.
if i'm right it will have the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping the cd tray from opening and also clamping the disc properly when closed.
hope this helps?
Mar 11, 2010 | NAD C541 CD Player
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
Nov 09, 2009 | NAD C542 CD Player
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
Dvd player
It is only a CD player, Will not play DVD's
Jan 01, 2008 | NAD C541 CD Player
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
mcl.vlb@tiscali.it
NAD C541 CD Player Logo
514 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
krisefisher
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
