Question about Olevia LT32HVM 32 in. LCD Television
Will not recognize a remote
I have the original remote and a direct tv remot(new batteries in both) and the tv will not work with either one. Turned on manually the tve works perfect, except for no remote. Sometime after it has been turned on for a tme the remote will work. Sometimes the remote will turn it on butin a few minutes the remote will not work again.
    Problem Solver:
  • 4 Answers
Olevia has no remote code like all the other brands... it is too new.  the universal remotes were made without Olevia codes because there weren't any.  i'm not sure if/when this will change, but i can't wait.  right now we mostly control the TV volume by using the stereo remote........
Posted on Sep 14, 2008
I got a replacement remote for the TV but it doesn't work on the TV. How do I get it to function with the TV
When you say "Replacement" you do not say if you bought an "Original type" replacement or one of those Universal ones which may or may not have the correct codes for the TV in question. Not all Universals have ALL POSSIBLE CODES.
You have two options.
1. Have your TV checked to find out if it is capable of responding to a remote control. If it won't then no remote whatsoever will make it respond ! Remote Receiving circuits fail as well !
2. If it is OK in that regard, get an original brand replacement Remote Control.
You can buy a Remote Control tester or you can take it to a TV technician who can check for you if the Remote is working.
Be sure to double check that you are using NEW batteries and that they are put into the remote with battery polarity as marked. You would be amazed how many times I have found that the problem was caused by persons putting batteries in the wrong way round !
Because of the shape of the ends of them, with some rechargeable batteries it is not so immediately obvious at to which is + and which is - unless you look very closely at the battery markings.
Jul 08, 2015 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Direct tv remote programming to operate tv
call directv. they are very helpful with programming remotes.
1-800-247-3288
Mar 07, 2014 | Samsung Televison & Video
Vizio remote won't control tv
I just had the same problem. I call Vizio and this is what they had me do that did fix the problem.
1. Unplug the TV
2. Hold down the power button on the TV for 30 seconds (yes, with it unplugged and do not plug it back in yet.)
3. Take the batteries out of the remote.
4. Press each button remote twice to ensure that they bounce back and are not stuck.
5. Place new batteries into the remote.
6. Plug the TV back in. Not into a power strip if possible. ( I did not have an available outlet so I used a power strip.)
7. Try turning the TV on using the remote. (My TV turned on. All of the functions worked - problem fixed.)
Hope that this helps.
Nov 17, 2013 | Vizio New Original M3D550KD Remote Control
Cant get the remote to work for menu options just started setting it up already programed to my direct tv remote now nothing is working or either remote t.v or direct tv remote
To diagnose a remote control problem follow these steps.
1) unplug the TV power cord, count to five and plug it back in. (reboot)
2) try to power on with ORIGINAL MANUFACTURER remote.
if that works- your TV and original remote are fine.
if that does not work:
4) try to power on with buttons on the TV itself- if it works- check your remote batteries and try remote again.
Direct TV and Dish Network remotes will ONLY operate SIMPLE function of your TV such as power, volume, input.
They will NOT access your TV menu.
Apr 12, 2011 | Televison & Video
My remote quit working.
If ur direct tv remote have problems,or it defective.Talk to ur direct tv satalite provider to get another remote.U can try website like 1-800-Remotes factory original.To buy ur Proscan tv original remote.
May 03, 2010 | Proscan 32LB30QD 32 in. LCD TV
My remote works to the tv, but not to my direct tv box
Is the RC the original for direct tv box?, if not you have to find the code for the direct tv box, separate from the tv rc code.
if it is the original rc for direct tv, look for the code in the original papers from direct tv.
May 22, 2009 | One For All URC-6131 Remote Control
Tv won't recognize remote codes
If the manufacturer of the universal remote cannot give you codes for the Symphonic you are out of luck. U will either have to get an original replacement or get a Harmony universal remote.
Jun 25, 2017 | Universal Remote Control Remote Control
Panasonic 42 inch HD Plasma TV (2 years old) remote sensor
take your tv and remote to a technician to check on your emitting diode and a photo senser, both are working but not very sensitive. the components are not gone but about to go. if you remove a senser from tv it can not receive, so that senser is sensing some thing, also check an amplifier just after a senser plse do that.
Nov 16, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Olevia LT32HVM 32 in. LCD Television Logo
353 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
