Nokia 7610 Supernova Cell Phone Logo
Posted on Jul 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dear sir, i'm using nokia 7610 supernova. how can i activate the internet settings for java applications.
Anonymous
Level 2:
  • Expert 133 Answers
  • Posted on Jul 06, 2011
Anonymous
Expert
Level 2:
Answers
133
Questions
0
Helped
37859
Points
489
Go into internet settings and see if java script is turned on.
Or you can go to Nokia new free site to download the application for free and other great stuff
http://mosh.nokia.com/
Regards
7610 supernova locked code
Hi what kind of lock code are you asking for? Is it a phone lock or a network lock?
If it is a phone lock, You must do a master reset for your Nokia 7610. This could restore your phone with default factory settings.
If it is a network lock, You need to enter the unlock code. You can get the unlock code either from your network provider or from any trusted vendor online. For example you can get the unlock code from www.unlocking4u.com/nokia-7610-supernova/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Nokia 7610 SUPERNOVA,
1 - Switch on your Nokia 7610 SUPERNOVA without any sim card.
2 - Don't bother as to what is displayed on your Nokia 7610 SUPERNOVA.
3 - Compose #pw+CODE+1#.
4 - The Nokia 7610 SUPERNOVA would then display the message "SIM Restriction Off" and will be unlocked!
2helpful
Nokia 7610 supernova Software update
you can contact the mobile service provider......
Sir i am not able to use opera mini or any browser which are based on java application. i am using bsnl gprs. so what should i do. can uyou please give me mannual settings. i am using nokia 7210 supernova
Go to Menu > Settings > Configuration Settings > Personal Configuration Settings
Add new 'Access point' and 'Web'
Now edit the Access point, choose its name (you can put any name)
Now fill the APN bsnlnet
No need to fill the proxy or port or username or password, the most important thing here is the APN
set this access point as the default access ooint
Now try browsing in opera mini
My Nokia 7610 supernova security code was error after I change other sim card. Please help...
May be you have set your security code on your phone. Try using 12345 or 00000 and see. If it's not working than you should provide your code that you have set by your own. Because the default code that are set by the company is 12345. If possible try to remember your code that you had set. If not you must go to the nearest mobile service centre.
Thanks for using FixYa All the best!
What is all restore factory code of 7610 supernova
If you didn't change the default Security Code, it should be 12345
That's the default security code for all Nokia Mobiles. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
4helpful
2answers
I can't login in eBuddy on my Nokia 6300...I download and instal but when I start eBuddy write ,,CONNECTION FAILED''...Your internet settings must be activated for Java Applications,or try...
Sir,
First of all you may read proper instructions what are the functions you have in your cell phone if Java application is not there you can downloaded. Without Java you can't do the needful.
ramesh
5helpful
Sir, I am not been able to use operamini or any such browser based java applications on my nokia 7210 supernova, please help me out I am using gprs mo of airtel now and been able to use it via my default...
the porblem is the gprs settings provided by airtel. it doesnt allow the third party software to use internet. so the problem can easily be solved by making manual settings.
6helpful
How to stop 'allow network access' pop up window in nokia 7610 supernova. Its very annoying that it always comes in between when i am surfing the net.
you download the java software first before you can run: on the phone to find your JAVA applications. Then select the section to stop the application software, press the left soft key operation, go to see the applications access the. Application access - communication - network access, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - communication - data interchange, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - data access - read user data, select Always allow the software without authorization certificate for each inquiry to the election.
application software access - data access - increased selection and editing of data is always permitted, the software did not authorize the certificate to select Always ask.
need to read the phone system, network or application software to download the JAD is authorized with the certificate.
this way can avoid the use of mobile phones, java software, always prompt " allow network access " this problem, this method is suitable for the Nokia S40 operating system models.
1helpful
I m using nokia 7610 supernova i want gprs setting for this
I would advise you to call up your customer care line and request them to send the settings to your phone so that you can automatically save them.
Regards
1helpful
Java application....
contact ur network or customer care and ask for i.p's codes
Mar 22, 2008 • Nokia 7610
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
