Question about DeLonghi Kitchen Ranges
The door on the oven of our Delonghi Professional cooker isn't shutting properly.
Have just fixed similar problem where door was not shutting properly by moving the rubber seals that are fixed on the oven so the ends are just tucked inside the oven cavity at the bottom, not swinging freely.
Hope this helps
Posted on Oct 27, 2008
Hi i need to find the wattage for my cooker pls it is dfs903 thank you
a cooker
wattage should be close label near to the 240 volts
heater elements go from 2500 watts to 1800 watts
the oven bulb is 40 w
list of parts for it has pictures to compare yours
Find Gas Cooker Spares Electric Cooker Spares
is this the beast ......dfs903
Delonghi Professional DFS903 90cm Cooker 26321246-i2ml2krc5iwy0vdznkpglsjk-1-0.jpg
Oct 21, 2016 | Kitchen Appliances - Others
Oven door not sealing correctly on our A106G Delonghi oven. It is sitting out slightly at the top
One of the door hinges may have come off track at the base of the door. Need to release the clamp on both hinges and get the door out for inspection.
New hinge can be got from
Delonghi Male Oven Door Hinge
Sep 03, 2014 | Ovens
Can i adjust the hindges as my door does not seal closed i have a delonghi pro cooker ess903 thanks colin
It is usual to be able to adjust oven door hinges.
Normally the only solution is to replace the hinges.
Hope this helps.
Jan 12, 2010 | DeLonghi Ovens
Cooker delonghi professional dfs903 6 ring hob has terible fan like noise whenever you turn the oven on which has now become unbearable and occurs whether using the grill, the oven on fan setting or not....
i had the same problem, the noise is coming from a circular fan located under the hob itself. not from the fan at the back of the oven.its a cooling fan.i bought a new one online around £70 and got a local gas fitter to install it. its a real big job and most if not all of the gas connections to the hob have to be disconnected its a big job.but worth it.
i have the same problem with the door,thats what im looking for.
if i find a solution ill let you know
Oct 05, 2009 | DeLonghi Kitchen Ranges
Delonghi px906 oven symbols have come off
Hi, I've just bought one of these with manual included.let me know if you're still having problems and I'll mail you a copy.
Roger.
Apr 09, 2009 | DeLonghi Kitchen Ranges
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
Kitchen Ranges Logo
597 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
