Question about Toshiba (PA3064U-1PCC) 802.11b Wireless Adapter
Toshiba pa3064u-1pcc macintosh
Hi, i would like to connect a toshiba pa3064u-1pcc to my macintosh G3 laptop, it seems that it does not work. is there a solution?
thanks
alex
  • Anonymous Mar 12, 2014
    driver pa3064u toshiba
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
You have to turn on sharing on both computers first, assuming the Toshiba allows it. Your Mac does. Then you can connect it using ethernet or USB. Unless they are both connected to a network, sharing is the only way to go or if it will even work.
Posted on Sep 10, 2009
Usb not recognized on macintosh powerbook g3
The Powerbook G3 will be using the original USB architecture and I suspect that your flash drives are using USB 2 and are not backwards compatible, so sorry I don't really think it is possible.
Dec 16, 2011 | Apple PowerBook G3 Mac Notebook
Tip
For the Mac G3. Are there Windows drivers?
This scsi controller is specifically for Apple Macintosh computers, name for the G3 macintoshes of the time. I am not sure if it will work in PCs, although I'd be interested in the information.
on Dec 22, 2008 | Adaptec PowerDomain 2930 (1796200) SCSI...
I got my laptop in May and about June my wireless stopped working and i have tried everything, and i just don't know what to do anymore i tried changing the network options and i tried turning the...
Hello drewann12 , HAve you tried uninstalling and reinstalling your wifi driver ?
If not try this, Clic Start , and pich run in that box type devmgmt.msc and perss ok button or enter key The device management will open , look for network section and clic on it to display your card installed you should see 2 card your physical card the one you plug your cord in and the wifi card right clic on that last one and choose uninstall Once this completed close all box and restart your computer upon restart Windows will detect a new peripheral (wour wificard) and reinstall the driver for it
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 09, 2011 | Toshiba (PA3064U-1PCC) 802.11b Wireless...
My system doesn;t boot up and I don't have the CD to boot up my system. When I brought the powerbook G3 it didn't with the CD. Please where can I get it from? I am in Ghana now. Thanks Ishmael
If you have another Macintosh that is working correctly, you can copy the contents of that hard-drive, including the Operating System onto an external hard drive.
To do this, install Carbon Copy Cloner on the working machine and plug in an external hard-drive. Then run Carbon copy cloner and make the source the computer's hard drive most likely named "Macintosh HD". Then choose to have your external hard drive be the drive where all of the data is copied. Then run the program and let it copy all of the files.
Once this is done, remove the external drive from the computer and plug it into your G3. Turn on your G3 while holding the Option (alt) key and then double click on the hard-drive image that is named whatever your external hard-drive is named.
Once your system boots up from the external hard drive, run Carbon Copy Cloner again and repeat the process again except have the source be your external drive and have the internal drive in your G3 be the disk that has all the data copied to it. Once this is done, turn off your computer, remove the external drive, and then boot up your computer again.
You will have an exact clone of the computer that you copied the data from and will just simply need to adjust the account settings as such as you see fit.
The external drive process can be skipped if you have a firewire cable. Simply connect the firewire cable to both computers and when you turn on your G3, hold the "T" key. This will turn your G3 into an external hard drive and you just have to carbon copy the files straight to your computer's internal hard drive.
If you do not have access to another computer mac computer, then you will need to go to the Apple Store and see if the Genius Bar can install the default operating system that your computer came with.
If for some odd reason you have the contents of an Mac OS install disc copied onto a flash drive or external hard drive, you can boot from that and use it in place of a disc.
Apr 15, 2011 | Apple PowerBook G3 Mac Notebook
Will th 3210 printer work on a mac
Yes. From the HP 3210 product specifications:
Macintosh system requirements Component Macintosh Operating system OS X v OS 10.2.8 and up Processor G3 or greater RAM Mac OS X v OS 10.2.8 and up: 128 MB Free disk space 500 MB Video display 800 x 600, 16-bit or higher CD-ROM drive 4x Connectivity USB 2.0 full speed, front and back ports (Mac OS X v OS 10.2.8 and up)
GOOD LUCK
Feb 21, 2010 | HP Photosmart 3210 Printer
Apple Macintosh PowerBook G3 Start-up problem
Your mac doesn't recognize the system folder. Try to find the original boot disks that came with the machine, and see if you can mount the hard disk while booting from the CDs. If you can, I'd backup the data as soon as possible and reinstall the operating system, including a full hard drive reformat. If you can't see the hard drive from the boot cd, another option is to hold down the T key during startup to boot the mac into "target disk mode" - this will allow you to hook up the g3 to another computer as an external hard disk in order to back up the data.
Oct 21, 2009 | Apple PowerBook G3 Mac Notebook
Cannot connect to wireless internet
go to run and type cmd.When a screen pops up type " ping www.google.com" , omiting these quotes and press enter.If you get something back which says things like ttl etc..then you have an internet connection..If you get a negative reply then you know you definitely have no connection.Try to reset your wireless connection and check if your firewall is stoping you..Also try on cmd prompt " ipconfig/all "..Check the results on google and maybe this could be helpful as well, on cmd prompt, type " ipconfig / iprenew" and press enter..Then when you are back at a blinking cursor then type " ipconfig / iprelease...Try these and if does not help then you should also consider rebooting the pc and restarting windows wireless configuration..(Google it and you will be fine)
Jun 14, 2009 | Toshiba (PA3064U-1PCC) 802.11b Wireless...
Toshiba (PA3064U-1PCC) 802.11b Wireless Adapter Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
