Question about Canonical Ltd. Ubuntu
Ubuntu error 22
I have two hard drives on my pc, one with ubuntu 7.10, the second with 8.04. I want to get rid of the 8.04, so I deleted all of it's partitions.
Now when I boot the machine, I get "Error 22" in Grub.
used Super Grub to boot into 7.10, and I want to edit Grub so that 8.04 is out of my machine completely and the pc will boot straight to the 7.10.
Thanks.
  • josh14 Sep 10, 2008
    I have a similar error, but not two ubuntu operating systems, one is ubuntu 8.04, the other is widows.
    How can i fix this error?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 14 Answers
While in Ubuntu do:
sudo fdisk -l to find the drive you want to boot to.
On the command line type:
"sudo grub", this will give you the grub shell >
If the disk you want to install the MBR is sda* for instance, then type (at the grub prompt):
"setup (hd0)"
then type "quit" at the prompt.
Posted on Aug 28, 2008
    Scholar:
  • 176 Answers
Go to /boot/grub
u must edit the "menu.lst" file as root
sudo gedit '/boot/grub/menu.lst'
Then go and modifiy the file as u need ...
Posted on Aug 25, 2008
Can I override the bios at startup so that it will recognize a new hard drive - for linux?
There should be no need to play around with your bios settings. Linux will install on a brand new hard drive as the sole operating system, or on an existing hard drive alongside Windows without any problem.
If you haven't already got a Linux distro, have a look at
http://www.ubuntu.com/download/desktop
Download whichever version of Ubuntu you prefer (LTS- the long term support version is recommended).
When the .iso file containing the operating system had downloaded, burn it onto a dvd, or install it on a usb drive.
Insert the dvd into the drive and restart or switch off/switch on the computer. The dvd will then kick in and offer you the choice of trying Ubuntu without installing, or a full install.
If you're using a new, empty hard drive just follow the on screen instructions and Ubuntu will install as the sole operating system.
If you already have Windows on your hard drive Ubuntu will give you the choice of either erasing Windows or installing Ubuntu alongside Windows. It's your choice.
Installing Ubuntu alongside Windows creates a dual boot hard drive. At start up you just choose which OS to use - Windows or Ubuntu. If creating this dual-boot system Ubuntu puts a (Linux) boot loader into the Windows OS so that Linux is recognised.
If you save the Ubuntu file to a usb drive you then have to change the bios settings so that your computer uses USB as the first boot device. Then restart your computer so that it boots in from your usb .. and Ubuntu will begin installing.
Whichever you use - dvd or usb - during the installation process Ubuntu will ask you how many GB of hard drive space it should use? You do not need to physically partition the hard drive. Linux will do it for you.
If it's a desktop PC you are using with Windows on the first hard drive and are fitting a second hard drive to install Linux on, or have installed Linux on the second hard drive .. and find that Linux doesn't appear at start up, it's because there's no Linux boot loader in Windows.
I quit using Windows many years ago.
Nov 01, 2015 | Everex IMPACT GC2500 PC Desktop
Tip
How Do I Correct the Error and Recover an Acer Computer hard drive?
In order to correct the hard drive partitions so the recovery program will work, you can use a variety of tools listed below.
1) Active@ KillDisk - Use their free killdisk program to wipe the hard drive clean off all partitions.
2) Ubuntu or another Linux alternative bootdisk. Create a boot disk for the Ubuntu Live CD and boot the computer from it. During the boot process it will ask to "Try Ubuntu without any change to your computer". This is the option you want. Once Ubuntu loads, find the partition editor program under the System, Administration menu..
To delete a partition, right click on the partition that you wish to delete and select "Delete" from the menu. Once you are sure that you've selected the correct partition, and are positive that you have backed up all the files or data that you wish to save from that partition, click the "Apply" button at the top of the Window, and the partition will be deleted.
3) Use the Acer Hard Drive Format Utility, on some versions of Acer computers when you have the option to create Recovery disks, the system creates a hard drive format utility CD as well. Boot from this CD and format the hard drive.
The utility will recreate 1 partition (C: drive), after the partition has been created, you'll be able to reload the HDD with the backup media. The file is an ISO image for CD media only (not compatible with floppy diskettes). Create a CD disc from the ISO image file using a CD writer program on another computer.
Once the hard drive partitions have been deleted by any of the utilities above, you can proceed with rebooting the computer using the Acer System CD and proceeding with the complete recovery of the system.
on Jun 25, 2010 | Computers & Internet
02-07 Fail HP Pavilion dv9000 Installed a brand new hard drive, Same error.
get all your information you need off of the HD and reinstall windows see if that will get rid of the problem.
Dec 13, 2011 | Computers & Internet
I have an acer 5315-2326 and I reformated the hard drive and tried to load windows 7 pro. It cant find the hard drive. I can load ubuntu but when I try to load windows 7 it says no hard drive found.How do...
I have seen hard drives where people had screwed around the partitions so bad that their computer would recognize it. I would recommend since Ubuntu can see it. Boot into a Ubuntu Live CD and delete any partition info so that it's a completely empty disc. Then try to use the Windows 7 DVD to install Windows. Comment back with your results.
Oct 25, 2011 | Acer Aspire 5315 Notebook
I have installed ubuntu in drive C(66gb) with windows xp,giving 13 gb space to ubuntu and rest to xp .now i have deleted the disk partition for ubuntu of 13 gb .when i start computer it shows grub error-17...
maybe if go to "start" right "my computer" click on "disk mangament" that ubuntu partition u deleted should be there and i think u need to add it to the windows partition allocate or allocated it i think...im not 100% ...make sure u do some reasrch before u make any changes....jus givin u my thoughts
Feb 15, 2011 | Dell Vostro 1014 Notebook
Netbook hard drive problem
Please login to the Computer with the Windows Operating System. Now, open the Disk Management window. Click on Start and select Run. In the Run command box, type Diskmgnt.msc and press Enter.
In the Disk Management window, you can view the 66 GB allocated space for Ubuntu. Right click on 66 GB space and select format. Now, you will get free space for Windows only.
Jun 30, 2010 | Acer eMachines eM2501162 Netbook
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Dec 19, 2009 | Computers & Internet
I was trying to load ubuntu onto a spare hard drive i had lying around. i used my everex stepnote 1500 note book to load the system on to the spare hard drive. now when i turn on my note book without the...
You should install Ubuntu from inside Windows with the wubi program. When you boot you will have Windows as the default boot option and Ubuntu as a second option. Choose the Ubuntu installation to reside on the external drive. You will connect the drive if you use Ubuntu.
If you do not do that, reinstall ubuntu on the external drive and choose to write the boot sector for GRUB or LILO on the external drive, not on the MBR of the primary drive.
Hope it helps.
Sep 12, 2009 | Everex StepNote NC1500 Notebook
Drive L: ?
So you've got rid of the ext partition but windows keeps displaying the mapped drive with and an error? Now you want to remove the wrong mapped drive.
Depending upon the software driver you installed - FS Driver, Explore2FS, you will probably need to uninstall that driver (it should be under Add/Remove in Control Panel). In some versions of FS Driver, I think it actually has it's own preferences under control panel which you can disable the mounting in.
May 05, 2009 | Dell Dimension 3000 PC Desktop
Ubuntu Installation
If your able to see the Windows Setup page, and get as far as your partitions, I would suggest deleting the partitions on the hard drive (make sure you know what your doing before trying this), as Ubuntu is mounted normally on a filesystem which Windows can not read (EXT2/3 for Linux - Fat32 / NTFS for Windows).
Once you have deleted all partitions, you can then create a partition (I'd recommend just clicking Install) and then chose the second option to format (not quick) for NTFS.
This then does a "secure" format of your hard drive, setting you up for a nice stable installation.
Apart from that, why don't you try jumping onto Ubuntuforums.org for Ubuntu Help, since Ubuntu is a much better Operating System (OS) than Windows, and there is a great community for helping people.
Aug 18, 2008 | Canonical Ltd. Ubuntu
Canonical Ltd. Ubuntu Logo
346 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
k24674
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
