Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi WS 55859
  • 1 more comment
  • danrobinson Aug 25, 2008
    thanks, i'll let you know what i find.
  • danrobinson Aug 27, 2008
    have not been able to find any poor solder connections. do you have a more specific area that i might need to look in?
    ok. i will let you know what the service people find.
  • 4,234 Answers
This is a classic symptom of a poor solder connection probably in the high voltage section. If you can solder, you can fix this yourself. Look for solder connections that appear grainy or have rings and resolder them. That should resolve the problem. If not, then we need to look for parts that are being effected by heat.
Keep us posted.
Dan
Posted on Aug 25, 2008
  • ABRsvcs Aug 27, 2008
    Unfortunately, the next step is to poke around while the set is operational. Since there are high voltages present that can cause injury, that is best left to an experienced tech. I have seen this symptom when the flyback transformer has started to fail. The internal insulation starts to break down and can cause internal short circuits. Once that happens, the high voltage section shutsdown resulting in no picture. I'm afraid it is time to get a repair estimate. Spend the $50 or so for a detailed estimate. From there we can walk you through the actual repair.
    Dan
Timer light continous blinking,tv won't turn on!!!
Thats a common problem thats almost always caused by failed capacitors on the DM powerr board. You can get the WS55859 DM repair kit from www.tvrepairworld.com the kit contains the upgraded capacitors and the CD with repair instructions.
May 30, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Timer light will not stop flashing and tv wont turn on
very easy repair caused by failed DM capacitors. You can get the WS55859 DM repair kit from www.tvrepairworld.com which contains the upgraded capacitors and the CD with repair instructions.
Mar 03, 2011 | Mitsubishi WS-55859 55" Rear Projection...
I'm getting an error code 32.On a WS-55859
32 isnt a valid code for your model. Mitsubishi model WS55859 has only 5 possible codes they are 12, 21, 22, 23, and 24 Double check the code again and resond to this same post and i will assist you.
Dec 04, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Blinking Green Light
Video Instructions for repairing TV blinking light WS-55589:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
I repaired mine using this and I am certainly not "handy". Good luck!
Jan 26, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi 55in. Big Screen TV
You have the wrong part number you need part number 334P278010 for the WS55859 flyback. If mitsubishi doesnt have one let me know and I will post a link where you can get one.
Jul 04, 2008 | Televison & Video
Wont turn on
work around convergence check voltage to convergence IC's if is ok, I' had same problem. find out one of the ic's was shorted
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Tv wont turn on
ok is in shut down mode kine of proteccion some of the fuses are pico fuses but you may have problem with convergence IC's that what I' check first if that is ok go to HVT .. if U still have problems e-mail me
Dm board on ws55859
That board is expensive  $500.00 or more
Oct 22, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
