Question about Electrical Supplies
Orbit walking sprinkler
Help. Why is my orbit walking sprinkler walking backwards? I do not know how to make it walk forwards. Is there some adjustment I accidentally hit or moved?
    Problem Solver:
  • 8 Answers
You probably just have the arms pointed the wrong way. To travel forward the angled part of the arm should be pointed in a clockwise direction. Aim them the other way and it travels backward.
Posted on Aug 05, 2009
My orbit is wired right, but only sprinkler number 2 will work. It comes on when I push for 1 3and 4
If indeed it is wired correctly, and your wires go where you think they do, then your Orbit is defective.
Test by removing wires 1,2,3, and 4.
Push for 1, and touch wire 1 to the connector for 1. Sprinkler 1 comes on? Touch wire 1 to the connector for 2. Sprinkler 1 comes on?
If yes to both, then Orbit is broken.
Sep 06, 2016 | Orbit Hardware & Accessories
Where do I get a new gear box for traveling sprinkler Orbit
Once again a couple simple GOOGLE searches...
Here is the item on the ORBIT website.
Orbit Irrigation Traveling Sprinkler Motor Assembly
I've never bought anything from these companies so I don't know how legitimate they are. Use at your own risk!
Orbit Traveling Sprinkler Motor Assembly
Aug 02, 2016 | Orbit Garden
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
I'm trying to find instruction manual for Orbit 58872N withuout success, could you help me?
Copy following link for several orbit resources.
Many Orbit manuals cover more than 1 model number.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Jul 21, 2012 | Hardware & Accessories
Orbit 57004 sprinkler controller does not turn on valves in Auto mode. Works OK in manual mode. All settings were checked carefully and repeatedly and verified by Orbit tech assistant by walk through
I am experiencing the same problem with my Orbit 57004. Did you ever figure out what was causing it not to start in "Auto" mode? he solutions above are not panning out for me.
May 12, 2012 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
My orbit tractor lawn sprinkler goes backwards instead of forward. So, it won't track on the water hose. What's wrong?
try turning the nozzles the other way - they should turn counter clockwise when looking from the top, not clockwise.
Jul 25, 2011 | Orbit Trvlng Tractor Sprinkler
Can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
Jul 22, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
I have an Orbit WaterMaster Sprinkler control, it is hooked up, but there is a light bulb that says power off and the sprinklers won't turn on. They will turn on manually at the sprinkler station. Can...
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Apr 11, 2010 | Orbit Sprinkler System Power Source...
Electrical Supplies Logo
426 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
