Question about Kitchen Appliances - Others
Replacement pan? where can I purchase a replacement pan for b&d all-in-one machine?
  • 1 more comment
  • Wawaite Aug 26, 2008
    I don't need the whole pan, just a new mixing blade. Can't find a parts site anywhere!!
    Jane
  • kengee26 Aug 28, 2008
    New pan for Welbilt ABM-100-4 kengee@comcast.net
  • parchyne Oct 25, 2008
    I'm looking for new pan, because my doesn't work (one blade not mixing dough).
Need a replacement pan for my Breadman TR845. Bread won't come out!
Posted on Sep 01, 2008
  • lees2palmyra Sep 19, 2008
    A seller on ebay claims to have the paddle (mixing blade).
    Still looking for a replacement pan.
    Found a phone number for Salton (they made the Breadman machine). Try
    1-800-233-9054
Wearever pots pans repairs
This is the wrong paragon. Paragon popcorn machines have only been around for approx 15 years. They were GMI prior, and did not make pots and pans.
Apr 23, 2014 | Paragon Kitchen Appliances - Others
The 2 rotating shafts in my Zo bread pan were stiff for awhile, needed rotating before filling the bread pan. Now, when unsupported, they drop out altogether. All pieces still appear to be together in...
The bread pan for your perticular model has no user-serviceable parts. You will be requires to purchase a replacement bread pan from Zojurushi to continue using your machine. Hope this helps.
Jun 12, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
My TR4000 machine is leaking liquids. The washers under the paddle are loose. I would like to purchase a new insert for my machine. Is this possible?
It is difficult to find such small parts or even find them. I recommend you just replace what is called the pan assembly which is the pan and parts under the pan, washers, pins, etc. already assembled for you. You just won't have the paddle so be sure to keep yours until your new pan assembly arrives..here is the site you can contact to order your parts. Best Wishes,
http://www.breadman.com/t-customer-care.aspx
Dec 16, 2010 | Breadman TR4000 Ultimate Dream Bread Maker
Replacement part for my Zojirushi BBCC-X20 Bread Machine
That sub component consists of a sealed bearing and seals that are spot welded onto the bottom of the pan. Unfortunately you can not purchase this assembly separately. Sorry Hank
Feb 12, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
Sep 21, 2009 | Kitchen Appliances - Others
Bread Machine non-stick starting to peel off
Since your machine is only about 6 months old, it should still be covered under warranty. I'd contact the manufacturer. (Contact information should be in the instruction manual). The teflon coating is just a sprayed on coating. Once it starts to peel, it's not safe to use them. It becomes hazardous (possibly eating it in the bread).
It sounds like you've taken care of the pan as it's supposed to be. If this was an older machine, I'd suggest ordering a new pan. You can find them on the internet quite easily.
Apr 01, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
West Bend Break Machine Model 41086 Parts
Do you have the manual for the 41086? I am in need of it.
Nov 18, 2007 | West Bend 41077 Just For Dinner¿...
Kitchen Appliances - Others Logo
218 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
